rev counter signal
- Thank you received: 252
15 Oct 2013 18:41 #86378
by j999pre
Grey pick up Jimny
rev counter signal was created by j999pre
Hi, where does the Jimny get it's signal for the rev counter from, I've just picked up a 55 plate vvt and the rev counter slowly climbs to Max over a period of time, it doesn't drop after a great change so add the revs up until maxed out. Odd one for you.
Grey pick up Jimny
- Dave cc
15 Oct 2013 22:10 #86422
by Dave cc
Replied by Dave cc on topic rev counter signal
I woulsd assume thru crank or cam sensor via the ECU Rhinoman would prob be the best to ask he is well versed in most things ECU
15 Oct 2013 22:17 #86424
Replied by helijohn on topic rev counter signal
Though not an answer to your needs James I did have a rev counter years ago which did this and there was an electronics fault in the tacho head itself.
16 Oct 2013 06:25 #86437
by j999pre
Grey pick up Jimny
Replied by j999pre on topic rev counter signal
I think I'll try and get hold of some clocks and sensors and have a play. I do like a challenge but this jimny had loads of them!
The push button 4wd isn't working either and is stuck in 4hi.
We will see over the next few days.
Grey pick up Jimny
- steffan
16 Oct 2013 06:37 #86440
by steffan
Replied by steffan on topic rev counter signal
If there's a man that can it would be you James ad love to help but your the jimny technical help line for me lol
16 Oct 2013 08:18 #86448
Just about every Jimny has a 4WD problem, king pin bearings problem, hole in the rear floor and that's before we get to what reguar cars need doing like cambelts etc.
Did you find out what sends the signal to the tacho - years ago I'd have looked at the distributor.
I hate modern cars with CATS and God knows what.
j999pre wrote: I think I'll try and get hold of some clocks and sensors and have a play. I do like a challenge but this jimny had loads of them!
Time to create page: 1.941 seconds
