1999 Jimny runs for 10 minutes and then stops
  • squarebore
28 Sep 2013 21:33 #84643 by squarebore
Replied by squarebore on topic 1999 Jimny runs for 10 minutes and then stops
j999pre wrote: So cam sensor or map sensor?
Cam sensor. Doesn't explain why it runs if you disconnect the MAP sensor but I'm sure there is a coll technical reason.
  • gus2000
28 Sep 2013 21:54 #84645 by gus2000
Replied by gus2000 on topic 1999 Jimny runs for 10 minutes and then stops
Hello
Did you replace all fuel from tank?
The old fuel (18 months) produces failures.
Try running the engine with the fuel tank cap removal (possible obstructed vent)
Replace the fuel filter. (the old fuel clogs the filter)
Cheers
Gustavo
  • squarebore
28 Sep 2013 22:25 #84648 by squarebore
gus2000 wrote: Hello
Cheers
Gustavo
Hi Gustavo, I didn't drain all the old fuel which was a mistake. I understood the fuel filter is actually part of the fuel pump and is in the tank. Is this right? It seems to have been the CAM sensor as I did the cold water test and it started right away. I've pulled the old sensor out and have ordered a new one from Ebay for AUD$61 delivered. It should be here on Tuesday and hopefully that will fix it. Cheers :)
  • squarebore
02 Oct 2013 08:31 #84962 by squarebore
Replied by squarebore on topic Re:1999 Jimny runs for 10 minutes and then stops
Update and thanks. I got the part today and quickly replaced it. I just went for an hour test drive and all is good. What a great resource this forum is. I hope I can return a favour sometime. Come to oz and say gidday. Cheers Michael
Time to create page: 0.405 seconds
