check engine light??
- 410shotgun
22 Sep 2013 08:40 #83961
by 410shotgun
Replied by 410shotgun on topic check engine light??
you need to scan it to find the fault
or you are pissing in the wind
- supergaz
22 Sep 2013 09:09 #83965
by supergaz
Replied by supergaz on topic check engine light??
You might need the fault code reader in the bigjimny shop. The ebay code readers do not work on all the G series engines.
22 Sep 2013 09:53 #83968
by facade
Replied by facade on topic check engine light??
If it is the single cam engine, you can use a jumper wire to make the lamp flash out the codes, have a search around for the info.
If you want a guess, and the car seems to run ok (may use a bit more fuel though) , the exhaust sensor on the engine manifold is the most likely culprit.
- chrisharman
22 Sep 2013 10:35 #83971
by chrisharman
Replied by chrisharman on topic check engine light??
Just played about with the fuses under the bonnet and its cleared the light.
Is this a good or bad?
23 Sep 2013 21:25 #84157
by Rhinoman
Replied by Rhinoman on topic check engine light??
Did you unplug the fuse for the EFI, if you did then you would have erased the ECU memory, you may find the CEL will come back on once the ECU has run through its checks.
Time to create page: 0.396 seconds
