Jimny cooling fan - spinning all the time?
- markyp2000
08 Sep 2013 12:52 #82501
by markyp2000
Replied by markyp2000 on topic Jimny cooling fan - spinning all the time?
It does what it does and is what it is its working so shut the bonnet and forget about it and dont worry untill the temp gauge goes higher than normal
- Sandspider
08 Sep 2013 12:56 #82502
by Sandspider
Replied by Sandspider on topic Jimny cooling fan - spinning all the time?
Surely it wastes a bit of power spinning when the engine isn't hot? And the Jimny doesn't really have power to spare!
Oh well - as you say, not a problem, and my temp gauge never goes above halfway up the dial, so I guess it does the job. :lol:
- jonesyba420
08 Sep 2013 13:00 #82503
by jonesyba420
Replied by jonesyba420 on topic Jimny cooling fan - spinning all the time?
Is this type of fan a problem when crossing water? Does it throw water all around the engine bay?
08 Sep 2013 13:21 #82504
by facade
Yes, but usually when driving in water you push the water in front of the car and drive at the speed of the wave, so the engine compartment is in the trough behind the wave.
I've done it a couple of times at the Landrover Experience, with someone else's car
I don't take the jimny through deep water, I'd rather spend an hour driving round it than 4 hours and a pot of cash fixing the water damage to brakes clutch and bearings.
Replied by facade on topic Jimny cooling fan - spinning all the time?
jonesyba420 wrote: Is this type of fan a problem when crossing water? Does it throw water all around the engine bay?
08 Sep 2013 16:23 #82518
Replied by helijohn on topic Jimny cooling fan - spinning all the time?
08 Sep 2013 20:09 - 08 Sep 2013 20:10 #82560
by Rhinoman
Replied by Rhinoman on topic Jimny cooling fan - spinning all the time?
It spins but doesn't really use any power until the engine gets hot when the clutch locks up. The fan is most efficient at 3000RPM so its designed not to turn any faster than that under normal use.
They do throw water all round the engine bay and as they are only designed to push air it tends to wreck them pretty quickly too.
Last edit: 08 Sep 2013 20:10 by Rhinoman.
Time to create page: 0.722 seconds
