Death Wobble Breakthrough - after all these years?
  • Hastiekid
31 Aug 2013 17:49 #81719 by Hastiekid
Gatallica wrote: Could well be.. alloy wheel quality can vary massively, although I'm not an off roader, so I'll bow to your greater knowledge.
I'm guessing that if you set a Jimny up for 4x4 use, it will not drive that nicely on the road?? I have driven a mate's SWB landy that he uses for off roading and it drives like a pig on tarmac! Lol.
Modulars are not Alloy they are sleels with a welded in center..............this is where I think my problem comes from i.e. the tolerance when the center is welded in is poor so effectively the wheel is not straight causing the same problem you have identified.
Ian
  • helijohn
31 Aug 2013 17:58 #81720 by helijohn
What it needs is for the wobblers to tell us if they practise cleanliness or not. I'm betting them that have this nasty affliction try it all. I put on my recently acquired alloys and right off got the nastiest wobble I've ever had at 45mph. I had cleaned the mating surfaces off with a wire brush, the surfaces on the wheels were really manky, those on the hub weren't to bad. It's either balance or untrue wheels/tyres in this case.
  • helijohn
31 Aug 2013 18:59 #81729 by helijohn
Ian
I thought modulars were bolted together which admittedly might cause balance problems? :unsure:
  • supergaz
31 Aug 2013 19:43 #81739 by supergaz
supergaz wrote: Welcome to Bigjimny. Yes you do have a good point, Many people may not clean components as much as others.
I have never had death wobble on my jimny which is used and abused!
The only cause of wobble I have had was the following
This is why I no longer choose to use Special Tracs on the road. I hate re-mould tyres.
These same alloys (Daihatsu fourtrak alloys) now have as little as 15 grams of balance weights on as I have quality new 31/10.5/15 tyres. Special tracs are so poorly manufactured they took the wheel balancer out of tolerence.
31 Aug 2013 20:07 #81742 by Halford
still not convinced it's that simple, I've 32mm spacers and all surfaces are clean but I haven't tried a micrometer on the spacers to check tolerances :unsure:
howvever, after my 40mm lift (thanks to HastieKid) my wobble went away :cheer:
and after new discs, it stayed away :cheer:
but it's just come back along with a squeak (wheel barrow sqeaky wheel sound) on the nearside front when I go over a bump or into a hole - guess this is a knacked BJ as noticed the rubber was split ??????
  • supergaz
31 Aug 2013 20:14 #81743 by supergaz
I think a'lot of the issue is down to how the wheel is fitted, as all nuts are torqued correctly in the correct order. Maybe not everyone does this correctly so the wheel does not mate flush.
Time to create page: 0.178 seconds
