Jimny Clutch Problems
  • ands
07 Jan 2014 06:34 #99475 by ands
Replied by ands on topic Jimny Clutch Problems
hunter1084 wrote:
ands wrote: im also having problems with my clutch pedal. its harder to step on the clutch than any other cars i have driven. i was adviced to try to lube the clutch cable first. if it gets better, then have the cable replaced. is this correct?
I dont know about cars but one of our tractors came to the point when you had to jump on it to push the clutch pedal in, mechanic just sprayed some CRC (WD40) down the clutch cable line and it freed it up to feel like new.
will try to use some wd40 and then add some synthetic grease. i am just not sure on how to make the grease penetrate the cable.
  • Stu stu
07 Jan 2014 12:13 #99489 by Stu stu
Replied by Stu stu on topic Jimny Clutch Problems
Warm grease up maybe
  • BensJimny
07 Jan 2014 20:22 #99549 by BensJimny
Replied by BensJimny on topic Jimny Clutch Problems
After a new clutch plate and throw out bearing resulted in no difference except for a lower biting point, i figured out the problem: As a jimny has a cable clutch, unlike a hydraulic clutch, after a while it will clog up with dirt, and result in it sticking and grinding on the inner metal sheathing of the clutch cable housing, removing the cable at both ends and re positioning along with a full coating of white lithium grease inside the cable housing it was running smoother, faster and no longer pinging up at the last second resulting in stalling, a bit of grease on the pedal bracket as well now means i'm enjoying gear changes much like those in the fast and the furious! would recommend after serious off roading (as its prone to clogging with dirt) or as a quick service as there was a big difference for me and was a 10 minute job! enjoy!
  • GuardianAngel
07 Jan 2014 22:04 #99573 by GuardianAngel
Replied by GuardianAngel on topic Re:Jimny Clutch Problems
Thanks for that. Mine is in bits awaiting a new fly wheel and clutch so I will have a look at the cable as well.
  • ands
09 Jan 2014 03:32 #99741 by ands
BensJimny wrote: After a new clutch plate and throw out bearing resulted in no difference except for a lower biting point, i figured out the problem: As a jimny has a cable clutch, unlike a hydraulic clutch, after a while it will clog up with dirt, and result in it sticking and grinding on the inner metal sheathing of the clutch cable housing, removing the cable at both ends and re positioning along with a full coating of white lithium grease inside the cable housing it was running smoother, faster and no longer pinging up at the last second resulting in stalling, a bit of grease on the pedal bracket as well now means i'm enjoying gear changes much like those in the fast and the furious! would recommend after serious off roading (as its prone to clogging with dirt) or as a quick service as there was a big difference for me and was a 10 minute job! enjoy!
thanks for the tip. I will have my clutch cable removed and lubed with silicone grease this weekend. will spray it first with silicone oil then add some synthetic lithium grease and try it out first.
09 Jan 2014 07:11 #99743 by robs5230
Replied by robs5230 on topic Jimny Clutch Problems
be careful with silicone oil / grease . i don't think it's for a metal to metal application. white lithium grease would be better.
standard jimny - for now
The following user(s) said Thank You: ands
Time to create page: 0.172 seconds
