oil leak between engine and gearbox?
- ne-crock
20 Aug 2013 18:36 #80496
by ne-crock
Replied by ne-crock on topic oil leak between engine and gearbox?
well i've had the cover off and i cant decide if its the sump or not,
how big of a job is it resealing the sump? just going to give that a go and some oil additive to revitalise seals and see if that fixes it,
- markyp2000
20 Aug 2013 20:07 #80521
by markyp2000
Replied by markyp2000 on topic oil leak between engine and gearbox?
Its tights coming off but a bit of elbow grease you should get it off just remember to drain the oil first and use a good oil resistant sealent i always use vw/audi sump sealent then refit all the bolts then tighten them all up
- ne-crock
20 Aug 2013 20:19 #80527
by ne-crock
yeah i'll drop the oil due a change anyway,
sounds simple i'll give that a go when i get a second,
cheers mark you've been a great help
- markyp2000
21 Aug 2013 16:23 #80627
by markyp2000
It tight coming past the front round crossmember and you may need to jack it up and surport on the chassis so the axle sits lower to make working on it a little easyer
Time to create page: 0.539 seconds
