oil leak between engine and gearbox?
  • ne-crock
09 Aug 2013 12:44 #79401 by ne-crock
oil leak between engine and gearbox? was created by ne-crock
so laying under the car i found this leak,
all most sure its engine oil as its getting low but i'm also burning a bit of oil so it could be that causing the low level,
any ideas whats the cause?
  • markyp2000
09 Aug 2013 12:53 - 09 Aug 2013 12:55 #79402 by markyp2000
Replied by markyp2000 on topic oil leak between engine and gearbox?
Sump sealent
Rear main oil seal
Head gasket
Rocker cover gasket
Alloy housing where the rear main oil seal fits
If single cam
Cam shaft sensor
Alloy mount cam shaft sensor sits in
I think that covers all thing sealing oil at the rear of the engine
Last edit: 09 Aug 2013 12:55 by markyp2000.
  • ne-crock
09 Aug 2013 14:01 #79406 by ne-crock
Replied by ne-crock on topic oil leak between engine and gearbox?
aha
so wheres best to make a start
  • markyp2000
09 Aug 2013 14:36 #79407 by markyp2000
Look at the rear of the head see if there is signs of oil may need to use a mirror then clean it off and run it
  • ne-crock
11 Aug 2013 16:32 #79583 by ne-crock
well i've looked around the head as best i can and for the bits i cant see i've shoved my hand and cant feel any oil coming from here,
if my sump was leaking would it be coming through my bell housing?
also been reading into the rear mail oil seal sounds like a big job? i have never taken a clutch apart or anything like that, what kind of prices would a garage be charging for such a job?
  • markyp2000
11 Aug 2013 17:17 #79585 by markyp2000
If your sump was leaking yes it would there is a metal plate held on with 2 10mm bolts take that off and you will see the back of the fly wheel and the end of the sump
Time to create page: 0.140 seconds
