EZ Locker/Lockrite in the front only.
  • Dave cc
25 Jul 2013 23:02 #78229 by Dave cc
Replied by Dave cc on topic EZ Locker/Lockrite in the front only.
And you brake 1/2 shafts coz both wheels want to turn at the same speed and when you steer they dont if im not correct if the 1/2 shafts didnt break you would find it very difficult to steer
To me a diff lock is a mechanical lock that allows both 1/2 shaft to be locked together big clonk big dog clutch or simaler
I beleive that unless im mistaken as i have never had 1 but a lockrite locks both 1/2 shafts together and will release one shaft if either wheel trys to exceed the speed of the other sort of the reverse of a LSD
26 Jul 2013 10:43 #78246 by Busta
There is a video here which explains it quite nicely:
Extra loading on the half shafts is an obvious downside. Do they break regularly on Jimnys? Compared to a Defender for example?
The bit I can't get my head around is the wheel speeds when turning (without the diff locked). The design of the locker removes the differential effect, so the inside wheel turns at the same speed whether turning or going straight. I want to know if this makes the car harder or easier to turn.
26 Jul 2013 10:58 #78248 by maverick
In my opinion, I would think (I don't actually know, but these are my thoughts) a Locker/ARB or similar in the rear and the FRONT would really only be used when the truck is ONLY used off-road and NOT on tarmac.
So i reckon that Off-road, the slippery surfaces, would allow for oppposing wheels/axles to rotate at differing speeds and therefore reduce (negate) the half-shaft breakages.
I have a Locker (Detroit PowerTrax) in my rear diff and i love it ... and yes you do get used to it!! Less right foot...
Jalapeño, IISY?
26 Jul 2013 11:56 #78251 by Busta
That was my thought Maverick. I'll be fitting a 2lo switch anyway, so I can still use low range on hard surfaces. I don't do pay and play days or rock crawling- the places where I'm likely to use 4wd are all soft mud or peat, where theere wouldn't be enough grip to break anything anyway.
The other issue at the moment, though, is that it seems nobody apart from ARB does a locker for the front axle on the Jimny!
26 Jul 2013 13:26 #78253 by maverick
Don't forget KAM Lockers
Jalapeño, IISY?
  • TomDK
26 Jul 2013 14:38 #78260 by TomDK
Replied by TomDK on topic EZ Locker/Lockrite in the front only.
maverick wrote: In my opinion, I would think (I don't actually know, but these are my thoughts) a Locker/ARB or similar in the rear and the FRONT would really only be used when the truck is ONLY used off-road and NOT on tarmac.
Don't see how that makes sense. At least when it comes to the ARB locker. When driving onroad it's disengaged and the diff acts as a normal diff. So an ARB locker rear/front would be the best option for an offroad/onroad vehicle.
