Sprung a leak! (rear axle)
- bigblue
18 Jun 2013 08:30 #74223
by bigblue
Sprung a leak! (rear axle) was created by bigblue
- ne-crock
18 Jun 2013 08:33 #74224
by ne-crock
Replied by ne-crock on topic Sprung a leak! (rear axle)
Rear wheel bearings most likely gone, and the play has now damage the axle oil seal,
I've just has to replace both of mine
The kit is available on the big jimny store
19 Jun 2013 08:04 #74343
by kirkynut
Replied by kirkynut on topic Sprung a leak! (rear axle)
^^^^^^^^^^^^ What he said!^^^^^^^^^^^^^^
The following user(s) said Thank You: bigblue
- gus2000
19 Jun 2013 11:17 #74358
by gus2000
Replied by gus2000 on topic Sprung a leak! (rear axle)
hello, leak diff oil or brake fluid?
Check brake fluid level on the reservoir.
Successes
Gustavo
Successes
Gustavo
- mc_nebula
25 Jun 2013 09:27 #75022
by mc_nebula
Replied by mc_nebula on topic Sprung a leak! (rear axle)
Probably diff oil. Like the others said, it's caused by a worn wheel bearing. If you have no/little mechanic experience, read the guide here -
www.bigjimny.com/images/documents/changi...ar-wheel-bearing.pdf
Best not to drive it over any significant distance/go offroad with little oil in the diff. It will not run totally dry because of the shape of the diff case. You should be ok to drive to a garage.
- Thank you received: 115
25 Jun 2013 09:53 - 25 Jun 2013 09:54 #75024
by maverick
Jalapeño, IISY?
Replied by maverick on topic Sprung a leak! (rear axle)
It takes me about one-hour to get the half-shaft out of a Jimny that has brake shoes fitted.
Get your replacement Wheel Bearing and Collar (if its an ABS collar then you need to speficy that) from the BigJimny shop then take your busted bearing and half-shaft to your local garage (with your new bearing/collar) and ask them to change them over ... my local garage charges me just £25.
Reassembly takes me about one-hour too!
Jalapeño, IISY?
Last edit: 25 Jun 2013 09:54 by maverick. Reason: typo
Time to create page: 1.016 seconds
