Electric window motor
- 2013gary
22 May 2013 12:15 #71375
by 2013gary
Electric window motor was created by 2013gary
Hi everyone,
My driver's side electric window no longer works and due to the smell of burning shortly before I assume the electric motor has given up. I've bought a replacement motor and mechanism for the window.
Is replacing it a weekday evening job or a whole Saturday/no knuckles left afterwards kind of job? Also has anyone done anything similar before? It looks fairly easy to get to by removing the inner door.
- VAXXi
22 May 2013 14:26 - 22 May 2013 14:27 #71387
by VAXXi
Replied by VAXXi on topic Electric window motor
Inner door lining is very easy: two screws for the handle, one screw for the latch and one plastic fixing cleary visible; the mirror cover (small black triangle) also comes out by pulling. Then you gently pry the door lining and that's it.
Motor has some sturdy screw; I guess you'd have to be very careful about lining up the glass and rails.
To give you an idea, here's how it looks like (door latch is top right, motor is middle right, locking mechanism is on the left):
Looks somewhat of a pain due to having to work behind the metal sheet.
Last edit: 22 May 2013 14:27 by VAXXi.
- Thank you received: 115
23 May 2013 09:18 #71435
by maverick
Jalapeño, IISY?
Replied by maverick on topic Electric window motor
it is a PITA ... get ready to lose some skin off your hands ... or wear kevlar gloves!!
I had to replace one, last year ... i wish that I had bought a door with one already in.
Jalapeño, IISY?
- 2013gary
23 May 2013 10:26 #71443
by 2013gary
Replied by 2013gary on topic Electric window motor
Thanks to both of you for the information and advice. Are there any jobs at all that can be done on a Jimny without losing skin on your hands??
- JivingDaddy
23 May 2013 10:39 #71444
by JivingDaddy
Replied by JivingDaddy on topic Electric window motor
Fitting a steering damper is OK. But then that's adding, not replacing.
Although I have heard that working in the confined spaces of a Jimny can result in obtaining an NVQ Gynaecology. :S
23 May 2013 10:59 #71446
by maverick
Maybe washing it??
Jalapeño, IISY?
2013gary wrote: Thanks to both of you for the information and advice. Are there any jobs at all that can be done on a Jimny without losing skin on your hands??
Maybe washing it??
Jalapeño, IISY?
Time to create page: 1.097 seconds
