New king pins and death wobble is even worse!
- Mattzuki
09 Apr 2013 09:13 #68237
by Mattzuki
New king pins and death wobble is even worse! was created by Mattzuki
As the title says really.
I've fitted the new king pins from Martin, and followed the 'how to' - all straight forward, just smelly and time consuming.
But...the death wobble is now worse than before! Any ideas what might be the cause? The disks and pads all had plenty left on them, but I'm wondering if I shouldn't change them as the pads looked like they had black spots/deposits on them.
Any advice would be most appreciated.
Cheers,
Matt
Cheers,
Matt
- markyp2000
09 Apr 2013 10:10 #68238
by markyp2000
Replied by markyp2000 on topic New king pins and death wobble is even worse!
Wheel balance at the front track rod ends
Discs and pads only show up wobble under braking and then the pedal pulses up and down
- goatboy
09 Apr 2013 10:14 #68239
by goatboy
Replied by goatboy on topic New king pins and death wobble is even worse!
There is tonnes of things it could be and lots of solutions but the top 3 seem to be
Wheel balancing
King pins
Track rod ends
Wheel balancing
King pins
Track rod ends
- Dave cc
09 Apr 2013 11:27 #68241
by Dave cc
Replied by Dave cc on topic New king pins and death wobble is even worse!
Defo check wheel balance my blue one all the joints and king pins are good but nearly shakes the filling out y teeth at 30mph going to try some of them balance beads juist to see what they are all about more than anything
- Alex09gp
09 Apr 2013 11:35 #68243
by Alex09gp
Replied by Alex09gp on topic New king pins and death wobble is even worse!
Get the wheels balanced on the car, problem sorted
- gus2000
09 Apr 2013 15:46 #68263
by gus2000
Replied by gus2000 on topic New king pins and death wobble is even worse!
Hello.
I attach a Suzuki Service Bulletin in
www.bigjimny.com/index.php/forum/7-jimny...heels-balanced#59278
Believe that the but important refers to the adjustment of the new bearings of the kingpin with spring balance.
Sincerely
gustavo
Sincerely
gustavo
Time to create page: 0.140 seconds
