Bleed valve sizes for front and rear brakes
  • GuardianAngel
26 Jan 2013 15:05 #59682 by GuardianAngel
Bleed valve sizes for front and rear brakes was created by GuardianAngel
In an attempt to replace my flexi-hoses today, I rounded off one of the bleed nipples on the front caliper :angry:
I have Googled around to see if I can get replacements, and came across this site:
So my question is, what size do I need for the front calipers, and in anticipation of it going wrong on the rear brakes, would these be the same size?
  • markyp2000
26 Jan 2013 15:38 #59697 by markyp2000
Replied by markyp2000 on topic Bleed valve sizes for front and rear brakes
Try bleading it out the pipe on the caliper crack it off peddel down do it up peddel off undo it peddle down and so on it should blead out i the end
  • GuardianAngel
26 Jan 2013 15:58 #59703 by GuardianAngel
Replied by GuardianAngel on topic Bleed valve sizes for front and rear brakes
markyp2000 wrote: Try bleading it out the pipe on the caliper crack it off peddel down do it up peddel off undo it peddle down and so on it should blead out i the end
I guess as a last resort I could, but if anybody knows the sizes, I can get replacements.
  • markyp2000
26 Jan 2013 16:04 #59705 by markyp2000
But this is only untill you get a replacment if you do this its your own discretion if the brakes feel ok
26 Jan 2013 18:49 #59742 by facade
There are only a couple of metric sizes, pop down your local motor factor and get one of each.
If you have rounded off the nipple, likely you will simply shear it off anyway when you try to remove it.
Give it an extreme wire brushing and spray with penetrating oil (plusgas/diesel even GT-85 at a pinch, not WD40) every day for a week, then pray really hard to your favourite deity as you gingerly try and undo it.
On a rear I would pop the rubbers out and warm it up around the nipple with a blowlamp. On a front I'd try the penetrating oil first, then when I'd sheared it off, pop the rubbers and warm it up and use an easyout on the base.
The following user(s) said Thank You: GuardianAngel
  • Northern-Wanderer
26 Jan 2013 19:38 #59750 by Northern-Wanderer
Replied by Northern-Wanderer on topic Bleed valve sizes for front and rear brakes
Years ago to help remove bleed nipples that where surrounded by rubber,plastic etc that could be damaged by "FLAME HEAT" we used to pour boiling water over the part.This worked more times than not
Time to create page: 0.142 seconds
