Body lift
  • Smoggy
13 Aug 2012 13:44 #46093 by Smoggy
Replied by Smoggy on topic Re: Body lift
I do take on board what you guys are saying about bodylift negatives: high cog etc. and only good for tyre clearance and little else, but I disagree, as since I did my bodylift I find it easier to route pipes, cables breathers etc out of harms way across the top of the chassis legs. It is also easier to inspect any rust prone areas such as the rearfloor pan above petrol tank, top of petrol tank, clearance space between top of chassis legs and vehicle floor. A point also worth mentioning; many owners of late have been having problems removing rear shocker top bolts - well this is much easier access with a bodylift. It makes things easier when fitting breathers too, especially the transfer box one. So all in all not totally negative.
  • Paul4x4
13 Aug 2012 14:00 #46095 by Paul4x4
Replied by Paul4x4 on topic Re: Body lift
Smoggy wrote: I do take on board what you guys are saying about bodylift negatives: high cog etc. and only good for tyre clearance and little else, but I disagree, as since I did my bodylift I find it easier to route pipes, cables breathers etc out of harms way across the top of the chassis legs. It is also easier to inspect any rust prone areas such as the rearfloor pan above petrol tank, top of petrol tank, clearance space between top of chassis legs and vehicle floor. A point also worth mentioning; many owners of late have been having problems removing rear shocker top bolts - well this is much easier access with a bodylift. It makes things easier when fitting breathers too, especially the transfer box one. So all in all not totally negative.
Of course there will be some benefits, but nothing is a good enough reason to lift the body up if you ask me. And because it just helps with the things you mentioned, there's nothing that one couldn't do without such lift. I MIGHT give thumbs up to a bodylift if someone would plan on fitting some bigger than 35" tires... ;)
But I think I have ranted enough about this topic in several threads, so I will take a small time out now, lol! :laugh:
  • JimnyX19
13 Aug 2012 20:26 - 13 Aug 2012 20:32 #46131 by JimnyX19
Replied by JimnyX19 on topic Re: Body lift
just to keep you all infromed just ordered 3 " susp lift rough country , going to go for oil filled as thats what is recommend by a few people , will be fitting next week or 2 with the bodylift and accessoires needed
Last edit: 13 Aug 2012 20:32 by JimnyX19.
  • TomDK
13 Aug 2012 20:30 #46132 by TomDK
Replied by TomDK on topic Re: Body lift
JimnyX19 wrote: just to keep you all infromed just ordered 3 " bodylift rough country , going to go for oil filled as thats what is recommend by a few people , will be fitting next week or 2 with the bodylift and accessoires needed
I take it you mean a 3" suspension lift?
  • JimnyX19
13 Aug 2012 20:33 #46133 by JimnyX19
yeah changed now cheers
  • winter
02 Apr 2013 21:57 #67665 by winter
Replied by winter on topic Re: Body lift
well said dave someone who knows what they talking about just saved me putting the same
Jimny-Dave wrote:
Paul4x4 wrote: Nylon lift blocks(if that's the case) are as good or better than aluminum ones because they don't corrode, so I wouldn't worry about that much.
Although, it's a good chance to return the set, and decide to go only with a suspension lift... ;)
Yup, that's why I swapped to Poly spacers, as ally and steel cold-weld together as the two different metals react against each other...
Time to create page: 0.257 seconds
