Body lift
- supergaz
07 Aug 2012 20:41 #45685
by supergaz
Not ever played about with a 05> jimny but as there is no transfer box lever it will be a much simpler task.
Replied by supergaz on topic Re: Body lift
Joakae wrote:
supergaz wrote: Suspension lift wont affect the transferbox, Only a bodylift as the transferbox is only attached to the chassis.
With a standard jimny transferbox and 2" bodylift I just bent the lever slightly with serious heat.
With the Rocklobster I have now that was a little more tricky.
Sorry to highjack this thread but is there anything to change on a 05> Jimny wihen doing a body lift with regards to the tbox? as it's electronic?
- mark1971
08 Aug 2012 06:19 #45697
by mark1971
Replied by mark1971 on topic Re: Body lift
You might want to check your ABS wires on a newer Jimny if your doing a body lift. My truck has a 3" suspension lift and when my axles are articulating fully the ABS sensor wires are getting tugged rather tightly, thats assuming you have ABS obviously.
- JimnyX19
09 Aug 2012 15:14 #45789
by JimnyX19
Replied by JimnyX19 on topic Re: Body lift
Just looking at my body lift spacers and theybare black plastic material? On jimny bits website it states they are ALUMINIUM not black plastic , has anyone ordered these from same site jimnybits and had same issue
- Smoggy
09 Aug 2012 16:37 #45792
by Smoggy
Replied by Smoggy on topic Re: Body lift
Got mine few months ago and they were aluminium. Are you sure theyre not black aluminium?
- Paul4x4
09 Aug 2012 17:36 #45797
by Paul4x4
Replied by Paul4x4 on topic Re: Body lift
Nylon lift blocks(if that's the case) are as good or better than aluminum ones because they don't corrode, so I wouldn't worry about that much.
Although, it's a good chance to return the set, and decide to go only with a suspension lift...
- JimnyX19
09 Aug 2012 19:58 #45817
by JimnyX19
No they are deffinetly plastic i can peel the frilly ends off , why would you recommend not to have it.? Im not happy with my order i have massaged jimny bits
Time to create page: 0.226 seconds
