Panhard rod and radius arms
  • TomDK
02 Apr 2015 21:23 - 02 Apr 2015 21:24 #141829 by TomDK
Replied by TomDK on topic Re: Panhard rod and radius arms
funkyjimny wrote: without the lower rear shock repositioners your lower shock bushes wont last five minutes , when the jimny is lifted the rear axle is rotated which puts the lower shock bushes at the wrong angle to the bolts through them.
That's odd.
I've had the 4" ORA lift installed for 1,5 years without relocation brackets, used for plenty of offroading and comps. Bushes still looks new.
Last edit: 02 Apr 2015 21:24 by TomDK.
04 Apr 2015 07:01 #141881 by Bosanek
Replied by Bosanek on topic Panhard rod and radius arms
Thank you very much for a prompt and clear answer.
My Jimny is LHD diesel, so it turns out that it is OK that my front panhard rod has a slight bend.
  • reflexsa
15 Apr 2015 12:41 #142538 by reflexsa
Replied by reflexsa on topic Panhard rod and radius arms
I've had something strange occur. I fitted a Jimnybits 2" lift and with this I purchased adjustable panhards.
However even with the standards panhards my axles are almost perfectly centre, in fact, slightly out to the left still.
  • TomDK
15 Apr 2015 12:46 #142540 by TomDK
Replied by TomDK on topic Panhard rod and radius arms
reflexsa wrote: I've had something strange occur. I fitted a Jimnybits 2" lift and with this I purchased adjustable panhards.
HAve you measured how tall the Jimny stands on standard springs compared to the 2" JB lift ?
  • reflexsa
15 Apr 2015 13:01 #142542 by reflexsa
I only have measurements from my 40mm spacer lift and the JB 2" lift. The measurements are similar.
The car is definitely quite a bit higher than standard springs alone.
