Panhard rod and radius arms
- ianR
01 Mar 2012 14:42 - 01 Mar 2012 16:59 #34602
by ianR
Panhard rod and radius arms was created by ianR
Hello,
Newbie question time !
I have just brought a Jimny, not that i've been in it yet and reading through the spec list of 2" body lift and 3" spring and shock lift with castor correction bushes and shock repostioners. It has not got uprated radius arms or panhard rods, do you think these will be needed or will it be ok on the current setup ?
Thanks
Thanks
Last edit: 01 Mar 2012 16:59 by ianR.
- kyrris
01 Mar 2012 16:48 - 01 Mar 2012 19:53 #34608
by kyrris
Replied by kyrris on topic Re: Panhard rod and radius arms
The castor correction bushes are meant for a 2'' lift but i have the same setup as you on my car and i don't have any problem. As for the panhard rods i believe you should change them so that your axles are in the center of the car.
Last edit: 01 Mar 2012 19:53 by kyrris.
- ianR
02 Mar 2012 08:23 #34636
by ianR
Replied by ianR on topic Re: Panhard rod and radius arms
Will fitting them make a difference ?
- Johnniehec
- Thank you received: 56
02 Mar 2012 16:58 - 02 Mar 2012 16:59 #34677
by Johnniehec
Replied by Johnniehec on topic Re: Panhard rod and radius arms
As kyrris said caster correction bushes are only meant for 2inch lift and yours is 3, but if the +3inch springs have sagged a bit if they've been on a while and done a bit of work then it'll be OK as is. If it wanders about on the road badly, doesn't return to centre then caster corrected arms might sort that.
If the axles are badly off centre, again cos of the 3 inch lift, then you'd need adjustable panhard rods to bring them back to centre.
john.
john.
Last edit: 02 Mar 2012 16:59 by Johnniehec.
- ianR
02 Mar 2012 21:24 #34697
by ianR
Cheers lads
- ianR
02 Mar 2012 22:49 #34699
by ianR
So what is the purpose of the shock repositioners ?
