OBD 2 Scanners - Any recommendations?
- teafortwo0789
27 Sep 2011 17:01 #22686
by teafortwo0789
Replied by teafortwo0789 on topic Re: OBD 2 Scanners - Any recommendations?
Thank you Vitara_mad, I'd read this in the manual, but 'forgotten' about it. If truth be known I'd failed to truly appreciate what it meant. Goes to show we should never stop learning. A good indicator if stuck in the wilds. I still have a slight preference for a meter, but money is always tight.
I'll giver it a try by initiating pseudo faults and see how I get on. Kind regards, Tony aka (Teafortwo)
28 Sep 2011 05:32 #22705
by kirkynut
Replied by kirkynut on topic Re: OBD 2 Scanners - Any recommendations?
I have what Martin has and It's great. I have all the codes printed in the glove box and have used It's code reading ability twice and use the gauge permanently.
I like to keep an eye on the coolant temps and where the car gauge doesn't move the maxi scan gauge warned me my rad was too full of mud to work! A saved engine!
The following user(s) said Thank You: teafortwo0789
28 Sep 2011 08:44 #22709
by MigCooper
what is the model you have? there are loads of different ones ... :dry:
Thanks
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re: OBD 2 Scanners - Any recommendations?
kirkynut wrote: I have what Martin has and It's great. I have all the codes printed in the glove box and have used It's code reading ability twice and use the gauge permanently.
Thanks
28 Sep 2011 11:44 #22713
Replied by mlines on topic Re: OBD 2 Scanners - Any recommendations?
28 Sep 2011 14:43 #22719
by kirkynut
And as I say, mine's the same as Martin's.
- ands
24 Oct 2013 01:43 #87687
by ands
Replied by ands on topic OBD 2 Scanners - Any recommendations?
sorry to revive an old thread.
i ordered an Ultra-gauge, this is something similar to Maxiscan and Scangauge2, from the US, and tried to plug it in yesterday in my 04 Jimny hard top. the scanner would only read "scanning".
how will I be able to check if my Jimny is OBD2 certified? Is there a fuse for the OBD port?
btw, I'm from the Philippines and our Jimny is Japan built.
www.ultra-gauge.com/ultragauge/
Time to create page: 2.831 seconds
