4wd Light flashing no drive from fr axle.
14 Aug 2008 18:25 #101
by Dave N
4wd Light flashing no drive from fr axle. was created by Dave N
Wondering if anyone can help my mate picked his jimny up at weekend we went out for few hours on sun afternoon after a few fairly high water crossings his 4 well drive light started flashing and he lost drive from fr wheels prop was still turning going it to diff just no wheels turning. Has any one sufferd from this or heard anything like it?
14 Aug 2008 19:05 #103
Replied by mlines on topic Re:4wd Light flashing no drive from fr axle.
Dave,
Its a very common problem.
The basic problem is that the Freewheeling hubs on the front wheels are not engaging. They are vacuum operated and when they fail to operate, the 4WD light flashes.
Somewhere in the vacuum system there is a problem. A pair of vacuum pipes (two for each wheel) run back from the front wheels to a pair of solenoids hidden below the battery and engine fuse box.
Check that the hoses on each wheel are in place and check the hoses for splits, follow them back to the solenoid as far as you can. Its usually a split/loose pipe.
The solendoids can suffer from dirt and water and there are a pair of tiny filters on them that need cleaning, quite a fiddly task.
If it becomes a regular problem then you can swap them for manual hubs from and SJ, but you will need a spacer ring (about 6mm) to fit them.
14 Aug 2008 19:25 - 14 Aug 2008 19:29 #104
by Dave N
Replied by Dave N on topic Re:4wd Light flashing no drive from fr axle.
Thanks for advice i will try that tomorrow. top fourm for info!!
Last edit: 14 Aug 2008 19:29 by Dave N.
15 Aug 2008 20:11 #108
by Asbojimny
scottishmudclub.com
Replied by Asbojimny on topic Re:4wd Light flashing no drive from fr axle.
The vacum pipes run along the front drivers side radius arms as well and head up towards the floor. I ripped all mine out the other weekend whilst off road.
That reminds me,better get it sorted!!!
scottishmudclub.com
16 Aug 2008 19:33 #110
by Dave N
4wd sorted thanks again!!
- Fearghal Murphy
17 Jul 2013 11:40 #77335
by Fearghal Murphy
Replied by Fearghal Murphy on topic Re:4wd Light flashing no drive from fr axle.
What was the problem in the end ?? did you have an easy fix ?? Well done anyway, glad it is back in business !
Time to create page: 0.448 seconds
