mini camcorder
15 Jan 2011 20:01 #9722 by ooky_123
Replied by ooky_123 on topic Re: mini camcorder
Yup, downloaded Drivers, instralled, still no joy.
Also cam doesnt want to play ball ... press the button, nothing happens ... format SD Card, set time .. 0 byte files on the card. then after.
left it on charge for 4 hours, followed teh instructions and the video ... still no joy .. somtimes it works for 10 seconds, then hangs, one light just stays on and I have to turn the cam off to reset it.
Just opened a support ticket with them and boxed back up the cam :( pity, was looking forward to playing with it tomorrow
Former owner of Little "Ooky", who has now started a new life in Shetland
  • vitara_mad
15 Jan 2011 21:06 #9724 by vitara_mad
Replied by vitara_mad on topic Re: mini camcorder
must be a faulty one cus mine seemed to work ok today ive not tryed using any drivers or as a webcam cus thats not what i want it for.
i put it in the windscreen & pressed record & went on a 40 min drive come back & pluged into pc & it had recorded 8 vid files like it should have done the only bit ive not worked out yet is im sure on the website it said it has audio but there is nothing in instruction about that & it did not record any audio but not sure if thats just for when using it as a webcam (i would rather not have audio for what im using it for anyway)
hope you get yours sorted as i think they are ok for £20
15 Jan 2011 21:30 #9728 by mlines
Replied by mlines on topic Re: mini camcorder
Mine has audio ok, when in webcam mode it can be disabled but in normal mode it seems to always be there.
  • vitara_mad
15 Jan 2011 21:50 #9729 by vitara_mad
just played back the vid again & turned vol upto top on pc speakers & i can just hear the sound but only just
do you know where the mic is on the camera ???
15 Jan 2011 22:14 #9731 by ooky_123
Mic is the small hole infront of the switch
  • a18suf
15 Jan 2011 22:14 #9732 by a18suf
Replied by a18suf on topic Re: mini camcorder
ooky have you pressed the reset button? Is t card in correctly as i put it in wrong when i 1st done it.
Time to create page: 2.072 seconds
