Jimny rear shock repositioner / spacers
- bryandenham
03 Jan 2011 19:10 #8798
by bryandenham
Replied by bryandenham on topic Re: Jimny rear shock repositioner / spacers
quick tip. Put a series of shallow saw slots on the face that sits on the old mounting, it stops the fitment twisting under stress, works a treat !! Bry DB)
- Gary Whenmouth
09 Jan 2011 16:12 #9175
by Gary Whenmouth
Replied by Gary Whenmouth on topic Re: Jimny rear shock repositioner / spacers
Just ordered the rear shock brackets from Big Jimny, AS THIS SITE IS SO GOOD!, removed my shocks from a welded on stud which i yet have to grind off, and i have now to drill out the old bolt as it has obviously sheared on the previous owner. Im planning on drilling through the old bolt and putting a long bolt through with a nyloc nut, ive noticed jimny bits sell this bolt as an option with their brackets, does anyone know what size this bolt is? Maybe Martin can help??
- bertbuckie
09 Jan 2011 16:29 #9177
by bertbuckie
Tell me about it.....and theres soooo much I want for the jimny lol
Replied by bertbuckie on topic Re: Jimny rear shock repositioner / spacers
Gary Whenmouth wrote: I wish January wasn't such a long month! Got paid so early in December
- Gary Whenmouth
09 Jan 2011 16:48 #9182
by Gary Whenmouth
My shopping list for my jimny is massive, im just doing things ATM that dont cost to much, ive just stripped out the interior today because it is so muddy im going to powerwash it inside, including all the hidden bits behind the interior trim. My jimny has been badly modded by the previous owner, dangerous suspension, springs inside springs and odd rear springs, fire happy electrics from winch and lights. Im working on getting the car safe first for the road. Its seen better days, however its solid and has very little rust
09 Jan 2011 18:04 - 09 Jan 2011 18:04 #9196
Replied by mlines on topic Re: Jimny rear shock repositioner / spacers
If you drill it out then the bolt size is whatever is appropriate for the resulting hole.
As standard its M12 but I drilled mine to M13.
As for the bolt length I found that long M13 or M12 Metric Fine bolts (Which is what it should be!) cost an arm a leg.
(Engineers look away at this point!!)Instead I went for M13 Studding, which I know is softer (and much cheaper) but the principle in my mind is that it will bend instead of snap (hard bolts). I have run for nearly 3 years with studding and its still fine.
Last edit: 09 Jan 2011 18:04 by mlines.
- Gary Whenmouth
09 Jan 2011 18:12 - 31 Jul 2011 17:56 #9198
by Gary Whenmouth
Thanks, Martin, think i need some new drill bits for work!
:pinch: I think those bolts will be hard to drill out. Cant wait to recieve the brackets from you, im sick of finding bodged jobs on my jimny, i cannot believe its not burst into flames! Im a electrical mechanical engineer so everything has to be perfect! especially safe!
Last edit: 31 Jul 2011 17:56 by Gary Whenmouth.
Time to create page: 0.171 seconds
