Transfer case swap?
- Thank you received: 1869
11 Mar 2022 10:12 #242250
Replied by Lambert on topic Transfer case swap?
Cheers. I have sent you the vin number. This is what I was worried about, too many systems talking to eachother. Though I don't have hdc which suggests a more primitive system. Hmm let me know what you find about the wiring diagram. Thanks.
11 Mar 2022 10:29 #242251
The long term goal with this is to regear for 29's and a super deep low range with a quaife in each axle and traction control on top as a backup for a wheel in the air. Add some adjustable dampers and I should be able to get wherever I point her. If what you are saying pans out though it may be simpler to sell the lever box and use the buttons one.
11 Mar 2022 12:25 #242254
Just looking at jimnybits and they do a sumo set for my existing case that is 15/104 percent but it is not cheap.
- Thank you received: 923
12 Mar 2022 11:24 - 12 Mar 2022 11:28 #242265
Replied by X8GGY on topic Transfer case swap?
I swapped from a push-button transfer box to a stick one with the gold Jimny I had, that eventually went to Gus-the-Gorilla..
With that one I also had to swap the diffs from 4.3:1 to earlier 3.9:1 to match the gearing for 29" tyres...
There was none of this electrickery ESP systems you speak of, to complicate things though...
Link to brief description and photos
(The sale of the 4.3:1 diffs will help though, useful for regearing earlier Jimnys)
Last edit: 12 Mar 2022 11:28 by X8GGY.
12 Mar 2022 12:46 - 12 Mar 2022 12:47 #242268
Being an automatic I already have the 3.9s and the sumo set would take me from 1.3 to 1.5 and 2.6 to 5.4. it's just that it's like 900 quid on it's own plus 1500 for the diffs 600 for dampers and the same for km3s. Not at the moment.
Last edit: 12 Mar 2022 12:47 by Lambert.
13 Mar 2022 09:42 #242281
Time to create page: 3.873 seconds
