Death wobble virus HELP
03 Mar 2022 09:48 #242135
by lightning
Replied by lightning on topic Death wobble virus HELP
Our Jimny is a new one so we've no issues with that.
However on my Land Rover the "death wobble" is generally caused by insufficient front swivel
preload, worn swivel bearings, or faulty shock absorbers/dampers
Have you checked the shock absorbers?
03 Mar 2022 11:04 #242136
by Busta
Replied by Busta on topic Death wobble virus HELP
Did you fit castor correction bushes with the lift? If not then your main problem in insufficient castor angle.
03 Mar 2022 12:50 #242138
by Conev
2002 Manual M13A jimny RHD
2" Black Raptor Lift kit
Ironman 4x4 steering Damper
8" steel wheels 215/75/15 AT100
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
Replied by Conev on topic Death wobble virus HELP
When i bought this lift black raptor said that i dont need castor correctors .. and also the wobble was there before i lifted the vehicle
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
03 Mar 2022 13:13 #242140
by Busta
Oh well if a salesman told you that it must be true!
Lifting the suspension reduces castor angle, and castor angle is there to give the steering stability. You have made it less stable and wobble has increased as a result. It's not the cause, but it will certainly be a reason for it getting much worse. As will the wider and heavier wheels.
03 Mar 2022 13:17 #242141
by Busta
Also what did the mechanic do to fix the oil leak on the ball joint? That is a classic sign that kingpin bearings are worn, but people often mistake it for other issues.
11 Mar 2022 17:17 #242255
by Conev
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
So i finally fixed my death wobble problem . Now the car rides like new .. i took it to 3 different steering alignment places and no one helped me .. the last guy told me that the car since was lifted the pan-hard has sto be adjusted because the previous owner had an adjustable pan-hard ..Also he told me that all the problem was starting from pan-hard bushed and i changed the to polyurethane ones .. also he checked the steering damped and all the components for steering .. He also balanced my wheels and tyres ..Everything now its okay no death wobble at all ..Its like having a new car in the road pretty smooth drive
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
Time to create page: 0.150 seconds
