How good are G3 Brakes?
08 Dec 2021 08:43 - 08 Dec 2021 08:44 #240548 by Scimike
I had reason at the weekend to implement a full-blown emergency stop thanks to a failed attempt of another vehicle to turn right in the path of my (Invisible) Jimny.Thankfully I managed to stop and avoid collision, but in doing so I was surprised that the ABS did to kick in. In other vehicles I have owned such none planned braking has always resulted in full blown tyre squeal (pre-ABS) or that buzzing assistance. The road was also damp which adds to this mystery.
My ABS works fine and the brakes are fully serviced, vehicle pass its MOT less than 4 weeks ago. So, it got me wondering if this lack of brake “power” is normal, just how good are Jimny brakes compared to other vehicles you own?
My gut feeling is this is normal, so any tips or mods that can be applied to improve the stopping performance?
It’s a completely standard G3, but I am aware those with bigger tyres seek better stopping power, so hoping for some suggestions. I am aware that stopping performance is subjective and difficult to benchmark, but worth asking as I tow with my Jimny which increases the need for better brakes.
Thanks
Mike
Last edit: 08 Dec 2021 08:44 by Scimike.
08 Dec 2021 09:43 #240549 by Roger Fairclough
The car stopped without any drama.
At least that is how the car saw the situation .
We humans look at a situation and if there is plenty of drama, tyre squeal, smoke etc, we feel satisfied, the brakes are doing there job: but if there is no drama, we feel kind of cheated!
Sounds daft I know but it harps back to the days of driving by the seat of one's pants.
It's one of the reasons I gave up on F1.
If you want reassurance, force the ABS to work. Reasonable speed, dry road, if you can find one ha ha, and try a full blooded stop. If the car just stops fast in a decent distance, try harder. You should be able to activate the ABS but then again if you are a product of that earlier generation that didn't rely on fancy gizmos to stop a car, then maybe you are not programmed to engage panic mode.
Well done that man.
Roger
08 Dec 2021 11:01 #240550 by Busta
Replied by Busta on topic How good are G3 Brakes?
Like most Suzuki products they are adequate without being outstanding. You should be able to activate ABS or lock the tyres. First step is to establish that what you have is working how it should be. As Roger says, have a play on a bit of empty road so you know what you're working with. The discs are non ventilated so repeated aggresive stops will quickly lead to brake fade. If anything seems amiss then get it looked at.
In terms of improvement, some people upgrade to ventilated discs and accompanying calipers from a Vitara. From memory they are the same diameter so don't improve the overall stopping power, but they will allow you to do more repeated fast stops before letting the smoke out. I'm sure there are some upgraded pads available for the standard Jimny brakes  too. Performance pads can give more power and resist more heat, but be wary of anything that mentions racing as they may rely on being warmed up to reach optimal performance. Not ideal in road conditions where you may need to do an emergency stop after cruising at 60mph for a few minutes and the brakes will be cold.
The following user(s) said Thank You: Scimike
  • Podge
08 Dec 2021 11:54 #240551 by Podge
Replied by Podge on topic How good are G3 Brakes?
I'd check your tyres, particularly your front ones. When I got the Jimny, there was the factory fitted Bidgestones on them, which were 8 years old at the time, starting to crack.
Replaced them with new Yokohoma Geolanders and they were much better at braking than the old Bridgestones. The old tyres would squirm and activate the ABS very easily whereas the new Yokohomas grip a lot more before the ABS kicks in
08 Dec 2021 13:15 #240552 by DrRobin
Replied by DrRobin on topic How good are G3 Brakes?
I had to do a mild emergency stop last week, my ABS kicked in, but I was surprised how smooth it was, the Jimny must use a very high frequency for the ABS.
That aside I think the brakes on my Jimny are very good, perfectly adequate for the size and weight of the vehicle and seems to have good progressive breaking.
I say this in the context of my other car a Boxster which also has very good brakes and a stream of company cars (BMWs) all less than 3 years old.
In the wet disc brakes can take a couple of turn to get rid of the water, it depends on what pads you have fitted, but unless it was icy then they should soon get up to working temperature and clear the disc.
You could change the rear drum brakes for discs, that would give you a bit more braking force, but possibly not in the wet?
08 Dec 2021 13:35 #240553 by Lambert
Replied by Lambert on topic How good are G3 Brakes?
On Dreadnaught with the bfg's on I had difficulty getting the abs to fire. Temeraire on the other hand with the Bridgestone ditchfinders fires the abs in the dry. It's down to the quality of your tyres.
Time to create page: 0.301 seconds
