Bolt on turbo
01 Oct 2021 15:06 #239050 by Motleycrew
Replied by Motleycrew on topic Bolt on turbo
Whats up with that hole?
01 Oct 2021 15:09 #239051 by Scimike
Replied by Scimike on topic Bolt on turbo
It will be fine.
You control the rate at which you "find a ditch" with your right foot, it's simply adjustment of your driving style for the power available.
Plenty of vehicles about before the advent of traction control that had the ability to spin, it's just these days the gizmos to sort it all out for you so people get use driving against the carpet.
Carry on the good work, keep the pictures coming.
01 Oct 2021 15:18 #239052 by Motleycrew
Cheers, its a silly project, will keep all updated though! I have seen a UK based company that sells a limited slip diff for around £700 if its to sketchy.
I decided that half a bar of boost will be safe as HKS sells a turbo kit for the swift m16a. Mine has a liana m16a, which has a more boost friendly compression ratio than that engine so wont be so knock limited whilst tuning.
01 Oct 2021 15:20 #239053 by Motleycrew
01 Oct 2021 20:21 - 01 Oct 2021 20:24 #239057 by lightning
Replied by lightning on topic Bolt on turbo
That kit looks good as it appears to include everything that you need, including the ECU.
Has anyone ever managed to modify a Jimny to make it permanent 4wd for road use?
Last edit: 01 Oct 2021 20:24 by lightning.
01 Oct 2021 20:51 #239059 by Motleycrew
The subaru justy had a AWD model and used the suzuki g13b engine in some markets. People use them as a budget rally car
