Bolt on turbo
23 Sep 2021 15:22 #238901
by 300bhpton
Gains are also dependant on the exact car and tune being applied. As a rule most n/a cars do not offer much with a tune. Especially if you are sticking with 95RON and have no mods. The only times this isn't true, is if the base tune is lacking for various reasons. Either with a very safe A/F ratio.
Or like the GT86 where it as a programmed 'hole' in the torque curve. Likely to be done for emissions reasons.
Modded engines and tunes are obviously a different kettle of fish all together.
Replied by 300bhpton on topic Bolt on turbo
Guess this would depend on the map, some will be for ultimate power. It would depend on a lot of things.The "map" or tune.... will be laid with drivability being the the focus, not ultimate power....
23 Sep 2021 15:30 #238902
by 300bhpton
If you want more grunt from the same displacement, then forced induction is the way to go. Although I think I'd personally prefer a supercharger to a turbo for off road work.
£8k for a built n.a engine sounds a lot IMO for a Jimny at least. At the end of the day, there really is no replacement for displacement. Meaning low end grunt and torque figures are going to be hard to radically alter from stock. Increase in power and moving the power curve up the rev range is what the majority of na mods will be doing.8k could see a fully built N/A engine fitted with more power and no reliability issues...
sniper
23 Sep 2021 15:43 - 23 Sep 2021 16:00 #238903
by sniper
8K spent on an n/a set up would put you around 150bhp with no lag or low rpm issues.... It would differ greatly from a standard engine... and be a more reliable option than boosting an engine that wasn't designed for it.... Forced induction is not always the way to go.
sniper
(note:- I think the point is lost, 8k Greddy kit fitted... I suggested that a "built" engine could be had for that money... Lightened, balanced, ported, flowed, custom induction, mappable ecu..... definitely not a standard engine)
Replied by sniper on topic Bolt on turbo
If you read the post, the 8k was the estimated cost of the Greddy kit fitted and tuned.....
sniper
sniper
Last edit: 23 Sep 2021 16:00 by sniper.
23 Sep 2021 16:29 #238905
Replied by Soeley on topic Bolt on turbo
If I was buying a bolt-on kit, I would expect it to contain everything you need to to the job properly, just extra for a rolling road session to set it all up.
It's a lot of money for an extra 30hp!
The following user(s) said Thank You: lookonimages
23 Sep 2021 22:23 #238918
by Keithy
Replied by Keithy on topic Bolt on turbo
24 Sep 2021 09:22 #238925
by 300bhpton
Is that not 130hp at the wheels? If so, that is a lot more than 30hp gain.
Time to create page: 2.555 seconds
