How To Improve The Ride Of My Jimny
18 Jun 2021 08:04 - 18 Jun 2021 08:04 #235903
by Gadget
Replied by Gadget on topic How To Improve The Ride Of My Jimny
It depends on what aspects of the ride you want to improve. In my experience fitting aftermarket shocks is likely to stiffen the ride - which may be a good thing if you're trying to reduce body roll, but bad if you want to make it smoother over poor road surfaces.
Also be careful with fitting larger tyres and pay attention to the load rating. Lots of larger size tyres have a higher load rating with stiffer sidewalls, so will make the ride harsher.
Last edit: 18 Jun 2021 08:04 by Gadget.
18 Jun 2021 09:18 #235908
by saxj
The Jimny however was designed as an off-roader, so on road comfort was a secondary consideration in the design of the suspension, and there won't be a lot that will improve the ride.
Replied by saxj on topic How To Improve The Ride Of My Jimny
First thing to look at is tyre pressures. The dealers tends to over inflate the tyres. Make sure they are at or slightly below what the manufacturer recommends.Hello all, i just bought the New 2021 Suzuki Jimny, however i didnt buy it for off-road use, still want to put little bigger tyres and probaby a 1.5 inch lift kit... However its a daily driver. Are there any suggestions to improve the comfort of the ride?
I am new to Jimny's etc i look forward to your advise
18 Jun 2021 14:10 #235913
by 300bhpton
Replied by 300bhpton on topic How To Improve The Ride Of My Jimny
What specifically don't you like about the ride? Figuring out exactly what is wrong will be the best of trying to address it.Hello all, i just bought the New 2021 Suzuki Jimny, however i didnt buy it for off-road use, still want to put little bigger tyres and probaby a 1.5 inch lift kit... However its a daily driver. Are there any suggestions to improve the comfort of the ride?
- lookonimages
- Thank you received: 72
18 Jun 2021 17:54 #235928
by lookonimages
The gen4 was 2.3 bar (33psi) on delivery. What a miserable drive to the nearest garage. Took it down to 1.7 bar (25psi) and it is such a pleasure driving it now.
Definately check tyre pressure.
Replied by lookonimages on topic Re:How To Improve The Ride Of My Jimny
Absolutely agree on checking tyre pressure. All vehicles bought last 2 years were way over recommended pressures.saxj wrote:
20 Jun 2021 18:48 #235988
by lightning
Replied by lightning on topic Re:How To Improve The Ride Of My Jimny
Good call on checking the tyre pressures, ours were at 42psi all round and the first owner had never noticed or checked them.
Probably assuming that the dealer had checked it before delivery.
They had done 1,300 miles with those pressures. l imagine it was a bit bouncy.
