How To Improve The Ride Of My Jimny
- CaptG
17 Jun 2021 22:02 #235878
by CaptG
How To Improve The Ride Of My Jimny was created by CaptG
Hello all, i just bought the New 2021 Suzuki Jimny, however i didnt buy it for off-road use, still want to put little bigger tyres and probaby a 1.5 inch lift kit... However its a daily driver. Are there any suggestions to improve the comfort of the ride?
I am new to Jimny's etc i look forward to your advise
17 Jun 2021 23:06 - 17 Jun 2021 23:07 #235881
by Scimike
Replied by Scimike on topic How To Improve The Ride Of My Jimny
Hi and welcome,
The Jimmy is a ridged axle 4x4 and will never get close to independent suspension ride quality, its design is very off road focused. You may change the feel for the better (or worse) by fitting aftermarket suspension or a lift kit, but I would recommend you try to get a ride in a modified vehicle to see if the changes suit your needs.
Dampers have a big impact, adjustable damper let you change the feel of the vehicle and may be your most flexible option. I would suggest these even if you decide to go with a lift, they will let you tune the vehicle "feel" to your requirement, which is after all a personal preference.
Good luck and enjoy
Good luck and enjoy
Last edit: 17 Jun 2021 23:07 by Scimike.
17 Jun 2021 23:09 #235882
by lightning
Replied by lightning on topic How To Improve The Ride Of My Jimny
The Jimny is an old-school live axle 4x4 and as such it will never drive like a car.
However, Suzuki have done a pretty good job of making such a small off-road vehicle drive OK on the road.
lt's much better than my Land Rover Defender, which is a similar design.
I am not sure you will make it much better, after all that's why car manufacturers moved away from live axles about fifty years ago.
You might change it by replacing the dampers and/or springs, l think some say that better dampers improved things.
But you are always going to be limited by the Jimny being designed primarily to work best off road.
- CaptG
18 Jun 2021 03:35 #235894
by CaptG
Replied by CaptG on topic How To Improve The Ride Of My Jimny
Thanks for the advise, can you send me a link or a suggestions of adjustable dampers that are available.
- Thank you received: 1983
18 Jun 2021 06:00 #235898
Replied by Lambert on topic How To Improve The Ride Of My Jimny
AVO do them. When my standard ones get old that's what I'm getting.
18 Jun 2021 07:53 - 18 Jun 2021 07:57 #235902
by lightning
l fitted adjustable dampers to my Defender and they did make a difference to the ride.
However the Defender rides quite hard as standard, so there's room for making it more compliant.
Making the dampers softer improved the ride on my Land Rover but made the on-road manners worse, particularly on poor road surfaces.
The Jimny seems to be set up fairly soft as standard, l am not sure l would want it any more so.
The best solution would be to fit adjustable dampers that are adjustable from inside the vehicle, if they are available.
Then you can alter the settings easily depending on what you are doing in the vehicle. You can get them for the Land Rover but they are over £1,000
Not sure if they are available for the Jimny.
Last edit: 18 Jun 2021 07:57 by lightning.
