Tyre pressures
05 Aug 2020 17:47 - 05 Aug 2020 17:48 #226108 by lightning
Tyre pressures was created by lightning
Just checked the tyre pressures on our 2020 Jimny and they were at 40psi all round.
l looked on the door pillar and it recommends 26psi front, 29psi rear.
On the Land Rover forum the discussion about tyre pressures is endless.
At the risk of starting another discussion, should l reduce the pressures to 26/29psi?
Last edit: 05 Aug 2020 17:48 by lightning.
05 Aug 2020 18:07 #226111 by wjamieson
Replied by wjamieson on topic Tyre pressures
40 psi is way too much. I have 215/75/15 AT tyres and run them at 27 psi. Would prefer 26 but then have issues with the TPMS in cold weather so 27 for me.
  • GeorgeC
05 Aug 2020 18:07 #226112 by GeorgeC
Replied by GeorgeC on topic Tyre pressures
NO!! 26/29 is too high, I found the low 20s to be better. :)
However, if you have TPMS the alarms will go off under 25.5psi, it becomes a balancing act.
05 Aug 2020 18:08 #226113 by wjamieson
Should have added that normally its just me in the car if lots in the boot then will raise to 28.
05 Aug 2020 19:05 - 05 Aug 2020 19:12 #226116 by Scimike
Replied by Scimike on topic Tyre pressures
If you have OEM tyres and a standard vehicle then you will not go far wrong with the pressure suggested by Suzuki. Manufacturers tend to spend a fortune trying to obtain the best performance out of every element on the vehicle, so the suggested pressure will be result of testing and consultation with the tyre producer. After that small changes up or down to your own personal preference are in order.
So yes is the short answer!
Last edit: 05 Aug 2020 19:12 by Scimike.
05 Aug 2020 19:15 #226117 by Lambert
Replied by Lambert on topic Tyre pressures
Without disappearing into the furthest reaches of the science standard tyres need standard pressure give or take a couple of psi.
Time to create page: 0.353 seconds
