Re:JB74W Wheel size help please
- nichwan87
14 Jul 2020 02:06 - 14 Jul 2020 02:28 #225032
by nichwan87
JB74W Wheel size help please was created by nichwan87
Good afternoon,
About to get a 2020 JB74W Jimny next month in Aus and would like to swap the alloys with steel rims
Can some of you very kind owners let me know if 15x6 offset 0 or 15x7 offset p3 would work better for this car?
Would the 7inch with a positive 3 offset cause any interference issues or would a 0 offset 6inch cause the tyres to protrude past the guards?
I'll be putting 215/75/R15 tyres on
Thank you
Thank you
Last edit: 14 Jul 2020 02:28 by nichwan87.
- Thank you received: 96
14 Jul 2020 06:08 - 14 Jul 2020 06:10 #225035
by DAGZOOK
Replied by DAGZOOK on topic JB74W Wheel size help please
Try this online wheel offset calculator it should answer your question.
www.1010tires.com/Tools/Wheel-Offset-Calculator#
The current SZ5 Jimny alloys are 5.5 inches wide with ET22 offset.
If I was replacing the stock wheels I would go for a 7 inch Wheel with ET0 offset, this will keep the wheel the same distance from your suspension components but will extend the wheel 40mm outwards giving you the effect of a 2 inch (ish) wheel spacer. With a 215/75/15 tyre you should have no issues, providing you don't choose an offset that brings the wheel closer to the suspension.
Last edit: 14 Jul 2020 06:10 by DAGZOOK.
- Thank you received: 1968
14 Jul 2020 06:26 #225037
Replied by Lambert on topic JB74W Wheel size help please
I thought that by examination we had determined that the gen4 had a 5mm positive et same as the gen3?
14 Jul 2020 07:23 #225039
Replied by mlines on topic Re:JB74W Wheel size help please
Yes, here is a picture live from our Gen4 this morning.Lambert wrote: I thought that by examination we had determined that the gen4 had a 5mm positive et same as the gen3?
14 Jul 2020 11:48 #225061
Replied by Lambert on topic Re:JB74W Wheel size help please
So taking that on board if you want the 215 tyre then a 6 inch rim is ideal. The et 0 option mentioned moves the wheel out 5mm which is fine but the extra width of the wheel actually makes it 7 mm closer at the edge. This is not a problem. The outside of the wheel will be 12 mm further out which is again not a problem.
14 Jul 2020 14:42 #225067
by DAGZOOK
Sorry Gents, I took the information on 'Jimnybits' website for granted. They clearly specify the OE wheels are ET22, I stand corrected.
www.jimnybits.com/jimny-18-on/wheels-whe...lar-steel-wheel.html
Time to create page: 0.224 seconds
