Wiring Connector by fuse box
16 May 2020 20:47 #222358
by Fossie
Replied by Fossie on topic Wiring Connector by fuse box
I have exactly the same thing , a wire from the positive connection with a 15 amp fuse fitted in that connector. The wire then runs along the loom alongside the fog light part of the loom into the mass around the vacuum connector ....though I think this is just where it was secured .......don't know what it's for but my fog lights don't work but the bulbs have continuity , but no voltage at the bulb end of the loom.
The following user(s) said Thank You: TillymintDLG
- Roger B
17 May 2020 07:37 #222367
by Roger B
Replied by Roger B on topic Wiring Connector by fuse box
Funny you should say that, my fog lights also do not work. I still have the problem of it not starting and a code reader cannot link to the ecu. Gonna have to send it away to get tested..........let's hope
- Roger B
17 May 2020 08:15 #222369
by Roger B
Hi again, is there an interior fuse box on a 2003 Jimny, if so where is it?
18 May 2020 10:44 #222474
by Fossie
In reference to this red aftermarket wire.....the fog light thing is a red herring I logically believe , it makes more sense to be a feed for an aftermarket radio, which would require a live feed for date / time display...15a is a touch overkill though......I say this because mind has a Kenwood jobbie fitted that updates the time date by a calander, so would need a low drain feed .
- TillymintDLG
18 May 2020 12:56 #222479
by TillymintDLG
Replied by TillymintDLG on topic Wiring Connector by fuse box
- Roger B
18 May 2020 13:12 #222480
by Roger B
Hi Gaz, Many thanks for that.
Do you know if any of those fuses supply power to the ecu?
