Rail use jimnys in New Zealand
  • bugslife71
02 Jun 2021 15:57 #235553 by bugslife71
Replied by bugslife71 on topic Rail use jimnys in New Zealand
Hi! Just need a little help po on my stock 2015 jimny.
I have with me a set of 18x8 rims with an offset of +38. I’m eyeing on putting on a size 235/55/R18 tires.
Will I encounter a problem mounting them on my jimny? Like tire rubbing inside the wheel wells, shocks, shock mountings or even with the brakes assemblies?
I will be not be using it for trails. If I do I would just use the stock ones as alternative.
Thanks so much.
02 Jun 2021 17:02 #235554 by Lambert
Short answer no they won't fit. Long answer they are overall taller and wider in tyre size and the wheels will be so far inside the arches that they will not have room to steer. Unless you are having to use stud pattern adapter spacers which might possibly help the offset the 38 of the wheels.
  • bugslife71
08 Jun 2021 10:01 #235662 by bugslife71
I gambled on the wheels and tires! Fitted great without any problem!
Time to create page: 0.939 seconds
