2WD Light flashing contiuesly
17 Mar 2020 11:17 #219978 by Busta
Replied by Busta on topic 2WD Light flashing contiuesly
It doesn't take long to find the leak if you are methodical, but worse case scenario is you have to bypass the whole lot with silicon hose, which will cost about £10 and take around an hour.
If the leak is in the hub it's because you have a wheel bearing gone. Fix that before it kills you and the 4wd will come back to life.
  • wilt
17 Mar 2020 12:23 #219982 by wilt
Replied by wilt on topic 2WD Light flashing contiuesly
Wow! Thanks for the informative reply.I only bought mine in January like you I didn't try all the features & am now left with this headache.I have been reading the threads on here & find the very informative as yours is,I was messing with the switches I did hear a bit of a 'clunk' sound after that the 2WD light was flashing I have checked the Vacuum pipe to the solenoid it seems I'm not getting 12volts to the solenoid so I need to trace that fault out if I can get a wiring diagram for my particular model '06' Jimmy's as for the Altenator mount probably change the belt first before it completely breaks away the grind into a little then pack it out with Aluminium Putty epoxy?
Time to create page: 0.140 seconds
