2WD Light flashing contiuesly
  • wilt
15 Mar 2020 12:09 #219882 by wilt
2WD Light flashing contiuesly was created by wilt
Hello Newbie here
How can I get the 2WD light to stop flashing although I have pressed the 4 WD & 4WDL can it be deleted by an OBD reader?
I have also read about there being a Vacuum Pump supplying vacuum to the Drive Hubs but I don't want to go down that road yet,by the way it's late 2006 modle
Thanks
Keith
  • TillymintDLG
15 Mar 2020 16:18 #219894 by TillymintDLG
Replied by TillymintDLG on topic 2WD Light flashing contiuesly
Hi Keith, I'm sure someone will be along to point you to the right info!
The vacuum is supplied from the intake manifold.
Gaz
  • wilt
16 Mar 2020 12:41 #219921 by wilt
Replied by wilt on topic 2WD Light flashing contiuesly
Hi Gaz,yeah been to that point took the pipe of the Vacuum Solenoid & was sucking good pardon the expression re-connected it to the solenoid took the bottom one off & noted with the Engine running no sucky,sucky I'm guessing the solenoid should be energised & delivering to the vacuum tank?coincidence or what not long had the Car and had new Back Box & Middle Section fitted new Clutch & Release Bearing fitted allegedly new Rear Shock Absorber & now this has happened apart from Front N/S Coil Spring has a piece missing & worst of all noticed when about to replace both belts theres a crack in the EngineBlock/Timing Case where the Altenator Adjusting Screw tightens think I got my hands full here
  • wilt
16 Mar 2020 12:44 #219922 by wilt
Nice pic by the way :o)
  • TillymintDLG
16 Mar 2020 21:30 #219955 by TillymintDLG
Cheers! Sorry to hear about your probs Keith..I have only had my '05 since the beginning of last December and I haven't had a look underneath mine yet. I have the flashing light too! I bought it from 45 miles away and didn't try the 4WD as wanted to be a good boy and get it on the grass first, and sure enough, it didn't engage 4WD and just got the flashing icon...Took it to my local garage and asked him to have a look for anything 'hanging off' and found one of the flexy pipes had come off, which he replaced but it still won't work!, as far as I can make out from the excellent posts on here, the ECU is waiting to get he signal that the hubs are locked..I'm wondering what is wrong? I roughly priced the major components to replace but it crept up to £1500+ so I've bought a pair of manual locking hubs and do what the other guys on here have said, and that is blank the inlet hole and short the contacts on the vacuum switch but not sure if that will stop the light from hell flashing? And will I be able to select low range too?
Have you thought of getting a mobile welder round to patch it in situ?
Gaz
17 Mar 2020 07:35 #219969 by kirkynut
The light is flashing to indicate that there's a vacuum leak somewhere in the system. That's all.
Due to the free-wheeling hubs being vacuum operated they have likely not locked and you are therefore unlikely to have 4wd.
There are many places that the vacuum can leak. It could be any of the pipes broken or pulled off. Or it could be a seal inside the steering knuckle.
It's for this reason that people get rid of them in favour of manual hubs and block off the vacuum system in the engine bay (see the wiki for instructions) to fool it. There's also a way of fooling it electronically (also possibly on the wiki) so you can just block the vacuum off at the manifold.
You can chase the leak if you wish but don't blame me if you go mad doing it!
The following user(s) said Thank You: TillymintDLG
Time to create page: 0.226 seconds
