Weedy battery in the gen 4??
16 Feb 2020 16:04 - 16 Feb 2020 16:04 #218602 by Gadget
Replied by Gadget on topic Weedy battery in the gen 4??
I'd definitely ditch the inverter and either wire in a perm-live USB outlet with a decent output, or buy a decent 12v accessory adapter. I wired this into my car so I can charge without the ignition on.
Last edit: 16 Feb 2020 16:04 by Gadget.
The following user(s) said Thank You: Andy2640
18 Feb 2020 07:13 #218691 by RainerK
I installed a LiFePo4 battery in my Jimny as the starting battery some months ago. 40Ah with integrated BMS.
So far everything works fine, I had no issue with starting in winter although this winter was not really cold, maybe -5°C. In case the battery would have a problem with the low temperature, I would first switch on the lights for a minute, then wait and try to start again - but so far this was not required.
How the battery behaves in the summer I can let you know in 6 months.
Regarding charging of your phone, as written above go for a 12V to USB charger. I installed one that is switched with the battery an one that is on permanent 12V. Without charging the permanent one uses less than 0.01A so there should not be an issue with haven this on all the time or get one with an off switch. If you install one on a permanent 12V make sure you check the idle consumption. There are some that use much more idle power and this could drain your battery within a few weeks.
Regarding you converter I think there is also another problem there. If your battery is good and can be quick drained 50% Within 15min and still start, then you used 20Ah within 15min, that means 80A discharge and that would be almost 1kW! The heat of 1kW you would easily detect, this is like a small hair dryer for 15min. So even if your converter is really bad, this cannot be without getting really, really hot. Even if it would just drain 40A this would be too much.
I would suspect, that your battery was on the edge and the additional drain was too much. As a recommendation I would definitely
- verify the level of the battery
- recharge the battery,
- check if the alternator charges the battery properly
- check if the battery keeps the charge
And maybe get a new battery.
All the best from Vienna!
19 Feb 2020 07:20 #218753 by kirkynut
If you have a Gen 4 your battery can only be a year or so old, so should be ok, you're just asking too much of it as per the above comments about the drain from an inverter.
A twin battery, split charged system sounds like the answer but an inverter will still drain bigger battery, it will just take a little longer and you'll be able to start the car off the original battery.
The only benefit of using the inverter is the speed of charging as the mains charger for most phones gives fast charging but the USB to 12v is slow, albeit does not take much out of the car battery.
So if you need to quick charge with the 3 pin charger you'll need to run the engine, otherwise just run it off a USB/cigarette lighter socket.
As a solution to just the phone, how about getting one of those portable power banks that you charge up at home which can charge a phone 2-3 times? You don't need to leave it in the car then.
19 Feb 2020 09:42 #218757 by Busta
Replied by Busta on topic Weedy battery in the gen 4??
You mention a kettle?! Using battery power to boil water is really inefficient. Why not try a simple gas camping stove like a jetboil or one of the many cheaper knock-offs. It will boil water a lot quicker and more efficiently without risking leaving you stranded. And you can use it away from the car. If you want to go really old school get a kelly kettle! They are great.
Also consider the voltages things work at. The car battery is 12v. The inverter puts out 240v. USB is 5v and a laptop charges at between 5 and 20v. Increasing the voltage to 240, to then bring it back down to 5 or 20v is very inefficient. Where you can, try to find things that plug directly into the cigarette lighter rather that using a domestic 3 pin plug. You can get car chargers for most laptops, for example.
19 Feb 2020 09:57 #218758 by Dan
19 Feb 2020 12:15 #218761 by 300bhpton
Gadget wrote: I'd definitely ditch the inverter and either wire in a perm-live USB outlet with a decent output, or buy a decent 12v accessory adapter. I wired this into my car so I can charge without the ignition on.
Nicely installed. Have seen a few people put USB ports here. My issue is, there is nowhere to physically put your phone to use a socket here though. Not unless you have long cables running over the steering column or worse putting the phone in the door pocket :( :(
Time to create page: 0.513 seconds
