Factory Service Manual (99501-81A20)
  • moocow
23 Dec 2019 23:01 #216745 by moocow
Factory Service Manual (99501-81A20) was created by moocow
Hello all! Long time lurker, first time poster.
I'll be needing to take apart the transfer case on my 2009 VVT Jimny, but can't find the FSM anywhere. Managed to get hold of the first half of the manual (99501-81A20-01E), but it doesn't cover any of the transmission.
Does anyone have a copy of what I assume would be called 99501-81A20-02E that they would be kind enough to share with me?
24 Dec 2019 05:04 #216748 by Lambert
Welcome to the forum. Have you looked on manuals lib. com?
24 Dec 2019 05:32 - 24 Dec 2019 05:35 #216751 by zukebob
Welcome. If you are looking for a later manual than the one you listed, it is only available as an online subscription. You won't find it available to download.
Check this wiki thread. The FSM info is available about halfway down the article.
Jimny Manuals Wiki
Edit: As a side note, if the manual you have is the proper year and doesn't list any information for what you are searching, it means it has been covered in an earlier manual.
Last edit: 24 Dec 2019 05:35 by zukebob.
  • moocow
24 Dec 2019 09:52 #216757 by moocow
Replied by moocow on topic Factory Service Manual (99501-81A20)
Thanks for the replies guys.
Sadly manualslib hasn't got it.
zukebob wrote: Edit: As a side note, if the manual you have is the proper year and doesn't list any information for what you are searching, it means it has been covered in an earlier manual.
I've been able to get the first half of the manual as denoted by 99501-81A20-01E, but not the second half.
Hopefully I'll be ok - it looks like the t case hasn't changed between models, was just put off by how the manual I have (A10) mentions a transfer shift knob in the cabin, which I don't have. Maybe this is just included because it was an option on the car? I'm changing the chain and pinions it runs on. All I need to do by the looks of thinks is take the gadgies off the front of it, open the case and change over the chain.
24 Dec 2019 10:28 #216759 by mlines
You have the electric transfer box.
The Wiki is a bit over complex as it covers "Types" and "VIN Numbers" so can take a bit of mental arithmetic to sort out.
As Zukebob says you have to work backwards to find out the earliest manual that your desired part appears in.
Being a VVT with electric it appears in 2005 as part of the manual 99501-81A10-01E
This is the best manual to google for you.
The following user(s) said Thank You: moocow
25 Dec 2019 19:53 - 25 Dec 2019 20:00 #216784 by HUN
I cannot give you a download link for the requested file, personally I've never seen 02 version, but if you accidentally DELETE some random letters from below you might discover something useful. Who knows? :whistle:
DELETEhttps://drive.goDELETEogle.com/file/d/1g8cBYCR7eswWMFAq5Pew973DJozENzvK/view?usp=drivesdk
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Last edit: 25 Dec 2019 20:00 by HUN.
Time to create page: 0.171 seconds
