Jimny Fox suspension
- Nikola
30 Sep 2019 06:44 #214042
by Nikola
Replied by Nikola on topic Jimny Fox suspension
That js adventure class. Have a lot of speed but also have heavy off road on some of stages...
- Nikola
30 Sep 2019 06:51 #214043
by Nikola
Stock shock fwd are 4 " travel and rear 6" travel. When jnstall +3" lift kit that have to be as per calculation 7" forward and 9 " for rear shock if i am not wrong. What is your opinion?
- Thank you received: 226
30 Sep 2019 07:12 #214045
by zukebob
Replied by zukebob on topic Jimny Fox suspension
What amount did you extend your bump stops? To get a shock with the most available travel on stock components, you would want a compressed length of about 12.5 inches for the front. It would be about 14 inches for the rear. If you have extended the bump stops by 2 inches, you would want something with approximately 14.5 inches compressed length in the front and 16.00 in the rear. From there you can look at6 what shocks have those compressed lengths and 8 and 10 inch travel. I am looking for the list I have.
- Nikola
30 Sep 2019 07:14 #214046
by Nikola
Some stages have speed like on rally raid but some of them have heavy mud and sand. So i have to find solution what will be best setup to cover everything...
- Thank you received: 1869
30 Sep 2019 07:15 #214047
Replied by Lambert on topic Jimny Fox suspension
Ok so something like rally raid. So you have the lift to give the suspension time to absorb the energy of a jump or such like. Ok have you removed the springs and dampers as suggested above and cycled the axles from full bump to a reasonable droop will the polyurethane bushes in place? Bear in mind that you have to allow some slack in the droop to accommodate the steering effect on the front brake pipes. Also with expensive dampers it is going to be sensible to use separate droop limit straps to avoid unnecessary damage.
30 Sep 2019 07:17 #214048
by zukebob
You and Lambert beat me to a reply. Bump stop extension length?
Time to create page: 1.103 seconds
