Mileage on m13a
21 Jul 2019 07:39 #211351 by Riccy
Replied by Riccy on topic Mileage on m13a
the nut stays still and the threaded bit goes in and out. More thread in = lower biting point on the pedal travel (or pedal has to be pushed further before anything happens).
approx 4" of thread there so plenty of adjustment options. If it helps, think of it as a bigger version of the adjuster on a bicycle brake lever. works in exactly the same way.
  • Chezzy71
21 Jul 2019 18:52 #211366 by Chezzy71
Replied by Chezzy71 on topic Mileage on m13a
That helps a lot thank you..
  • Chezzy71
21 Jul 2019 19:33 #211368 by Chezzy71
So is this the newer sealed type bearings
September 2008 should be the newer..?
And when looking at any is this the most obvious way to tell....?
Jimnys gen3 made between 2008-2018 (factory "type 7" and newer), the 4WD controller allows shifting "directly" from 2WD-H to 4WD-L and vice versa.
Actually, it does not shift directly - the same process of going through 4WD-H mode happens, just automatically by the 4WD controller instead by the operator.
22 Jul 2019 05:00 #211374 by Lambert
Replied by Lambert on topic Mileage on m13a
It's a manufacturing adjustment that was carried out in 2009 without any further revisions to the gearbox. There's no immediately obvious visual identifier.
  • Chezzy71
22 Jul 2019 11:24 #211395 by Chezzy71
Can the pre 2009 box be rebuilt with post 2009 bearings.... If I was to have a faulty box...
22 Jul 2019 15:15 #211401 by Lambert
Yarp!
The following user(s) said Thank You: Chezzy71
Time to create page: 0.296 seconds
