Mileage on m13a
- Chezzy71
20 Jul 2019 16:53 #211326
by Chezzy71
Replied by Chezzy71 on topic Mileage on m13a
Mot advisory from 4 years ago
Gearbox oil loss
Date tested
12 August 2015
PASS
Mileage
95,384 miles
MOT test number
6382 3492 5233
Test location
View test location
Expiry date
22 August 2016
Advisory notice item(s)
Nearside Front Axle swivel joint has slight play (2.5.A.3b)
Headlamp glass damaged o/side and n/side. Gear box has oil loss.
What are advisories
Gearbox oil loss
Date tested
12 August 2015
PASS
Mileage
95,384 miles
MOT test number
6382 3492 5233
Test location
View test location
Expiry date
22 August 2016
What are advisories
- Thank you received: 1988
20 Jul 2019 17:31 #211327
Replied by Lambert on topic Mileage on m13a
There's been a few people recently having boxes rebuilt and they seem to be paying between about 4 and 7 hundred quid depending on where they are and if they have removed the box themselves or not.
- Caelite
20 Jul 2019 18:14 - 20 Jul 2019 18:14 #211329
by Caelite
Replied by Caelite on topic Mileage on m13a
Mine is up at 135k miles (I bought it at 99k), '06, VVT, manual. Engine runs strong, bit tickity, planning to look at the valve clearance next service (any time this month).
Gearbox I think is needing work soon, have had a leak at the rear propshaft, seal has been replaced twice & propshaft is in good condition, the seals last a few week then begin to leak again, which makes me think there is play in the output shaft, indicating the shaft bearing is on it's way out.
Last edit: 20 Jul 2019 18:14 by Caelite.
- Chezzy71
20 Jul 2019 20:00 - 20 Jul 2019 20:02 #211331
by Chezzy71
Ive been offered an 05 plate cat C repared
And although its C im pretty sure it should have been D, it was very light damage to the drivers side front corner.. its 41,000 and its pretty much never failed an MOT from the records online which also confirms mileage, it drives very very nice apart from the clutch being high and no service records at all..
The guy bought it damaged and has had it 4 years and done over half the 41,000, ( i think he said it was on 19,000 when he got it )
it has 5 brand new 195 80 15 hankook dynapro tyres
Underneath from my inspection is by far the cleanest ive seen in all the usual places
Its £2300
Its £2300
Last edit: 20 Jul 2019 20:02 by Chezzy71.
20 Jul 2019 20:04 #211332
Replied by Riccy on topic Mileage on m13a
The high clutch biting point is easily adjusted underneath with just a pair of grips. Where the clutch cable enters the bellhousing there is a black plastic nut. give that a few turns and it will sort the biting point position out easily enough. If the clutch isnt slipping then its just adjustment. If it looks to have been adjusted already then maybe factor in a clutch change in the next year or two (circa £200 all in).
I wouldnt worry about it being a cat c from the description. Sounds like an ideal car.
- Chezzy71
20 Jul 2019 20:51 #211335
by Chezzy71
Thanks,, I'm happy you agree and yeah that's my exact thoughts on the clutch, it has been adjusted before.. after backing the plastic nut off do i wind the thread outwards to lower the bite on the peddle, as i did notice the cable end block is touching the gearbox and defo won't adjust the other way..
Time to create page: 0.534 seconds
