Heater and fan
  • Mole
31 Jan 2019 07:21 #202161 by Mole
Heater and fan was created by Mole
Morning. A couple of questions on the heater and fan are there known bits that need clearing out at all as mine dose seem to blow very hard on full mainly the side vents for the side windows and never seems to get very warm even when the engine is up to temp. I have a 2002 model any input would be greatly appreciated
Carl
31 Jan 2019 07:29 #202162 by Lambert
Replied by Lambert on topic Heater and fan
There are 2 white plastic lever assemblies either side of the blower that are operated by wires from the dash. These are both exposed to errant feet and get brittle with age. Check they're functional. Then there is a little access slot on the passenger side where the cabin filter may or may not be check that for debris. After that it's a matter of taking the dashboard out to get at the actual matrix and blower to assess those. It may also be prudent to flush the cooling system thoroughly with the heater on full go.
  • Mole
31 Jan 2019 07:42 #202163 by Mole
Replied by Mole on topic Heater and fan
Ok thanks I have checked the cabin filter as I read about that but have got one and also cleared and put fresh coolant in the other week tho didn't have the heater on when I did it. so I'll check the little leavers next it's a pain it all works just dosent get that hot
31 Jan 2019 07:50 #202166 by Lambert
Sounds like a control issue at that point or a partial matrix block. Good luck.
The following user(s) said Thank You: Mole
  • Mole
18 Nov 2019 09:35 #215732 by Mole
Coming back to this as the weather is cold again my heater is still not the warmest. Are there pipes I can disconnect to flush just the heater matrix ?
26 Nov 2019 13:12 #215976 by Max Headroom
Replied by Max Headroom on topic Heater and fan
Mole wrote: Are there pipes I can disconnect to flush just the heater matrix ?
A good question - my heater doesn't seem half as good as the one in my neighbour's Jimny!
Time to create page: 0.171 seconds
