Re:Re:Re:All of a sudden no central locking and no start.
  • Webb
21 Jan 2019 11:00 #201319 by Webb
Lambert wrote: Sorry I wasn't clear i meant the car battery under the bonnet not the key one.
Thanks mate, yeah I understood, the main battery under the bonnet.
  • Webb
21 Jan 2019 11:07 #201320 by Webb
Sorry to keep adding things,
Could it be or is there a device that reads the key. Maybe that could be it as both the immobiliser and c/locking don’t work with the button now, also I only have one key
21 Jan 2019 11:32 #201322 by Lambert
Yours is a lot older than mine but as I understand it the factory immobilizer has an induction loop round the ignition switch that reads the chip in the key, the door opening is a separate function controlled by the circuit board in the key. Bu you're describing the immobilization procedure on your car as being via a separate unit correct? Can you post a picture of the things involved in the usual start procedure it may offer further insights?
  • Webb
21 Jan 2019 11:35 #201323 by Webb
Lambert wrote: Yours is a lot older than mine but as I understand it the factory immobilizer has an induction loop round the ignition switch that reads the chip in the key, the door opening is a separate function controlled by the circuit board in the key. Bu you're describing the immobilization procedure on your car as being via a separate unit correct? Can you post a picture of the things involved in the usual start procedure it may offer further insights?
Thanks for your reply, I really appreciate it.
I’ll put some pictures together and post them
  • Webb
22 Jan 2019 02:33 #201392 by Webb
Problem solved, it was the immobiliser.
I ripped it out and bypassed it. All good
22 Jan 2019 04:58 #201394 by Lambert
There you go then. Just don't forget to look into a further additional layer of security like a steering lock or such. Don't make it easy for the criminal classes.
Time to create page: 0.315 seconds
