Engine conversion combined with suspension lift
03 Oct 2018 15:09 #196475 by Jefferies
TomDK wrote: Trail master +3" diesel springs would be very suitable. They're actually only 2" longer than stock but made of much thicker wire than most other springs for the Jimny.
Those would be very nice but i can't stretch to them unfortunately
03 Oct 2018 18:06 #196477 by Riccy
Jefferies wrote: How helpful!
I'd imagine its because they are setup to get rid of the Jimny lean so yes it would have an affect. Why else would they give the option when buying them??
Correct, but this can be overcome with a simple small spring spacer on one side ;-)
03 Oct 2018 18:39 - 03 Oct 2018 18:40 #196478 by Jezz
Or you could just swap the springs from side to side. If you really are after a budget lift, You could go to a breakers and get Honda CR-V or MERC 180 springs. But with budget springs comes budget problems.
It's been fettled just a tad.
Last edit: 03 Oct 2018 18:40 by Jezz. Reason: spelling
  • TomDK
03 Oct 2018 19:07 #196480 by TomDK
I can only recommend that you save up a bit more for those springs. They are a perfect match to what you need.
04 Oct 2018 00:49 #196484 by zukebob
Jefferies wrote:
i'd like to get it right first time if possible
I don't think this group is trying to press you into a purchase you will regret. On the contrary, I think they are trying to guide you to your initially stated criteria. I think Tom's recommendation is a very good one and I would hate to see you spending time and money to come to the same conclusion.
Time to create page: 0.156 seconds
