Fake cruise control
01 Oct 2018 06:32 #196393 by Lambert
Fake cruise control was created by Lambert
Whatcha. It's almost time for the annual reconnaissance mission to the North Coast. This involves a 9 ish hour motorway stint which is tedious. In other vehicles I have either real cruise control or as a compensation a sort of accelerator pedal foot rest rather than in the Jimny having to maintain a steady foot position for hours on end resulting in a dead ankle. I have seen Dave's push rod arrangements and while functional off road I wouldn't be happy at 70 mph. I have half looked at a foot rest like for the left foot in the automatic one but mounting it suitably isn't immediately obvious. I had also considered a choke cable to the throttle butterfly but again I can't see an obvious way to route one. What else is an option?
01 Oct 2018 07:24 #196395 by Scimike
Replied by Scimike on topic Fake cruise control
I think your only option is a choke cable to the throttle butterfly..... or maybe some way of locking the throttle pedal via a cable /electrical solenoid.
An electrical solution is better as you could have it disengage when the brake lights come on.
I have a mechanical solution in my Land Rover, its the PTO hand throttle which just lifts the throttle butterfly. Its ok on the flat, but you slow on hills and rev the conkers out of it when you forget and drop the clutch..
01 Oct 2018 08:27 #196397 by Lambert
Replied by Lambert on topic Fake cruise control
Hmmm the simpler the better for me, though I take the point about it screaming if I dip the clutch for some reason. More thought needed.
  • rappey
01 Oct 2018 18:10 #196410 by rappey
Replied by rappey on topic Fake cruise control
There are some "cruise control kits" on ebay that will work with a manually operated throttle linkage..
01 Oct 2018 18:47 #196416 by Lambert
Interesting. Thanks.
02 Oct 2018 16:42 - 02 Oct 2018 16:43 #196443 by X8GGY
Replied by X8GGY on topic Fake cruise control
Lambert wrote: Whatcha. It's almost time for the annual reconnaissance mission to the North Coast. This involves a 9 ish hour motorway stint which is tedious. In other vehicles I have either real cruise control or as a compensation a sort of accelerator pedal foot rest rather than in the Jimny having to maintain a steady foot position for hours on end resulting in a dead ankle. I have seen Dave's push rod arrangements and while functional off road I wouldn't be happy at 70 mph. I have half looked at a foot rest like for the left foot in the automatic one but mounting it suitably isn't immediately obvious. I had also considered a choke cable to the throttle butterfly but again I can't see an obvious way to route one. What else is an option?
Oh, no no no...
My -
Is to set the revs for a winching operation, or for after one to recharge the battery (leave it running at say 2,000 rpm...)
NOT to be some sort of cruise control! :blink:
Last edit: 02 Oct 2018 16:43 by X8GGY.
Time to create page: 0.760 seconds
