Jimny transmission problem?
- rubinow
24 Apr 2018 06:38 #192103
by rubinow
Jimny transmission problem? was created by rubinow
Hi,
I am new to the forum , I have a 2001 Jimny Auto and when driving the Jimny seemed to lose power and was crawling even when foot pedal
pressed to floor, I pulled over and after 30 min tried again.All was good until after 300 metres the problem returned.This happens after a minute of driving.If I wait 20 or 30 min it is normal again until.
The mechanic told me I need my transmission rebuilt but I suspect a sensor.
What do you guys think?
24 Apr 2018 11:25 #192114
by kirkynut
Replied by kirkynut on topic Jimny transmission problem?
I doubt it needs a full re-build. A change of automatic transmission fluid would be my first thing to do.
When ATF gets old and burnt it cannot work as a hydraulic fluid.
If that doesn't work I've no idea as I'm not knowledgeable enough about auto's.
It worked wonders on my Beemer though.
- mickt
24 Apr 2018 11:39 #192115
by mickt
Replied by mickt on topic Jimny transmission problem?
Pull the box dipstick and check the colour of the oil. If really black then it will need replacing. Smell it and if it smells burnt then the clutches have probably worn out and it will need a rebuild/swap
24 Apr 2018 13:28 #192116
Replied by mlines on topic Jimny transmission problem?
Blocked/collapsed catalytic converter??
24 Apr 2018 16:43 #192117
by kirkynut
Yes, as Martin says, these are classic symptoms of a blocked cat. How blinkered I was with the idea of the gearbox in mind.
mlines wrote: Blocked/collapsed catalytic converter??
- mickt
24 Apr 2018 19:38 #192123
by mickt
In the first post it was difficult to ascertain if it was engine or box related. If you had defined the engine revs as opposed to power then it would have pointed to the engine i.e engine revving high but car going slow seemingly with no power or pedal to the floor but engine not revving. Still a cat defect will be cheaper than a box defect which is good for you.
Time to create page: 0.673 seconds
