checking/filling gearbox oil
10 Apr 2018 15:48 #191526 by auchenblae
Agreed I have a 2 post lift and a nice warm garage and it is a pig of a job to get the oil in there.
It's not a failure to accept that sometimes you have to use a local garage if you do not have the facilities.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
10 Apr 2018 16:11 #191527 by Scimike
Don't do it on a Halfords (or any) car park, it's one of the most dangerous places in the world.
People are happy to drive around it at excessive speed, bump into your car, or simply just drive over the poor Halfords employees who are in plain sight in high viz as they attend to a bulb.
Your legs sticking out from under the vehicle will be a fair unseen target.
I am one of the poor targets :(
Work colleague got his leg broken in one such incident.
10 Apr 2018 16:30 #191528 by Busta
Replied by Busta on topic checking/filling gearbox oil
I had some success refilling using the 1 litre plastic oil cans with the build in spout (The 4 inch long half inch diameter type spouts, not the short fat ones). I was able to get the whole oil can up beside the gearbox with the spout in the fill hole and squeeze about 700ml from the can into the gearbox. Doing this with 2 cans, then pouring the leftover 300ml from one can into the other and repeating the process, I was able to get the oil up to the correct level relatively easily.
10 Apr 2018 16:43 #191529 by Riccy
Replied by Riccy on topic checking/filling gearbox oil
No eBay APP ID and/or Cert ID defined in Kunena configurationI wont say dont do it in a carpark, but only because everyone else has!
I will say to check you can undo the filler plug before trying to drain it, as thats critical.
The best tool I have found for filling it up is one of these:
10 Apr 2018 17:11 #191533 by Scimike
+1 VOTE for the above tool^^^
I have one which I use on my Landy, not seen action on Jimny yet, but should work just as good.
10 Apr 2018 18:03 #191536 by auchenblae
You two must have the fabled ones that do not leak via going past the piston and out the hole the pushrod comes out.
I have binned a few 500ml ones and two of these due to looseing loads of oil via the pushrod.. These ones are circa £35 and they have double seals on the pistons that leak.
www.ebay.co.uk/i/222410526780?chn=ps&dis...id=1058853793&crdt=0
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.157 seconds
