checking/filling gearbox oil
- doddy
10 Apr 2018 06:14 #191504
by doddy
checking/filling gearbox oil was created by doddy
good morning
this weekend I will be checking/filling my gearbox oil on an 07 jimny . I have not done this before , are there any tips ? thanks in advance
- Max Headroom
- Banned
- Thank you received: 217
10 Apr 2018 10:20 - 10 Apr 2018 10:32 #191512
by Max Headroom
Replied by Max Headroom on topic checking/filling gearbox oil
My only experience with gearboxes is with ones associated with helicopters but the principles are the same!
Part of the process with draining and refilling helicopter gearboxes was to get the oil hot; we actually did what we called "a hot drain & flush".
This involved getting the gearbox oil up to operating temperature then draining it while it was hot.
(Removing the filler-cap before draining allowed the thinner (hot) oil to rush out quicker bringing with it as much debris as possible).
The g'box was then refilled and the process repeated.
Finally the g'box magnetic plug was inspected and/or cleaned or replaced and fitted with with a new seal/gasket, and the g'box refilled with new oil; job done.
A bit extreme I guess; we have cars not heli's, but if you haven't done the oil for a long time a flush might well be good a good idea particularly if you find particles on the plug.
Other tips...
Wear the right correct PPE - some eye protection and disposable gloves - oil can be very nasty stuff.
Know the quantity you're expecting to come out and have the correct sized container! Be aware of it being hot!
Have rags paper or other absorbent materials at hand if you have a drama and miss the container!
Fit the plug with a new seal BEFORE filling the g'box!
Make completely certain you refill the g'box with the correct quantity of the correct oil, ad fit the filler plug
Someone here mentioned that a Redline oil helps with g'box selection issues but I don't have details of which oil exactly.
Sorry if some of this includes the teaching of egg-sucking, but you did ask :laugh:
Other tips...
Last edit: 10 Apr 2018 10:32 by Max Headroom.
- auchenblae
- Elite Member
- Thank you received: 25
10 Apr 2018 11:35 #191514
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic checking/filling gearbox oil
You need a 10mm square toll to remove the filler plug. It is a real pig to get to and the space between the plug and the transmission tunnel only allows a shart length tool to get in there.
I have a number of 10mm square tools and I will be doing a how to early next week and wll show the tools that will not get in there.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
10 Apr 2018 13:51 #191519
Replied by Daniel30 on topic checking/filling gearbox oil
Make sure you can undo the filler first before the drain plug, I normally hold a tube while my mechanic pours it in from standing beside the jim and let gravity do the work
Quantities and spec are in the wiki Forecourt section if you need then
- doddy
10 Apr 2018 14:05 #191523
by doddy
Replied by doddy on topic checking/filling gearbox oil
thanks for the replies ; with regards to putting in the new oil ; is there a knack ; or does the new oil container have a built in spout .
sorry for the daft questions but I have never replaced gearbox oil and because its to dangerous for me to do it out side my home I was going to drive to Halfords ; buy the oil and fill the level in their car park (with a blanket underneath for spills) so ideally I want to go fully armed
10 Apr 2018 15:35 #191525
Wouldn't advise doing it at halfords,
If you're not able to do it at home I would recommend a garage do it then it is also there responsibility to recycle the old oil once they have finished.
