Engine oil leak and hole in flywheel bell housing
- Thank you received: 1971
08 Apr 2018 05:24 #191441
Replied by Lambert on topic Engine oil leak and hole in flywheel bell housing
By all means clean it up and see if it persists, but if it does then the supplier needs to be given opportunity to rectify.
- apayne
08 Apr 2018 11:22 #191445
by apayne
Replied by apayne on topic Engine oil leak and hole in flywheel bell housing
Update: looks to be all sorted!
I cleaned up the oil on the flywheel housing and the hole is actually meant to be there. It's purpose is so that you can manually turn the flywheel (if you ever change the timing belt/chain and need to get TDC etc).
Cleaned up the oil that seems to have come from the oil filter when changed and everything seems to be okay for now. If this changes I'll let you know!
Thanks again for your help.
08 Apr 2018 11:25 - 08 Apr 2018 11:26 #191446
by facade
Replied by facade on topic Engine oil leak and hole in flywheel bell housing
That hole is supposed to be there!
Probably lets out any oil that leaks from the gearbox front seal.
If you are going into water that deep you will fill the axles and chassis with water.
I'd drive 50 extra miles rather than go through water deeper than the tyres, 2 hours driving is a lot less trouble than changing the kingpin bearings and the axle oil
Last edit: 08 Apr 2018 11:26 by facade.
08 Apr 2018 19:43 #191460
by kirkynut
Replied by kirkynut on topic Engine oil leak and hole in flywheel bell housing
I wish all problems were that easy to solve!
- apayne
09 Apr 2018 07:58 #191478
by apayne
Time to create page: 0.342 seconds
