Engine oil leak and hole in flywheel bell housing
- apayne
07 Apr 2018 19:43 #191418
by apayne
Engine oil leak and hole in flywheel bell housing was created by apayne
Hi all, I'm very new to this Jimny community so please bare with me (3 days exactly!) and seem to have already stumbled across a couple of problems sadly. I purchased a 2001 Jimny with 78k on the clock this week from a car garage near me. When I got it home I looked underneath the car briefly and thought I spotted a bit of wet oil on the underside.
I jacked up the car to look closer and have come across two problems: a small hole in the flywheel bell-housing and an oil leak from somewhere else (I know that there isn't oil in the flywheel section so it's not leaking from there).
Firstly, is the hole in the bell-housing a problem and what's the best way to go about fixing this, do I get it welded or will it be fine left as it is? I have been advised by a friend who's a mechanic that it should be fine if left as it is even if going through puddles.
Secondly, any idea what might be causing the engine oil leak? There's oil coming down from the oil filter and seeping down one side of the oil sump and dripping from there by the looks of it. The oil filter was changed this week as part of a service and so not sure if when changed oil simply leaked from there?
Going to get back under the car tomorrow and clean up the oil and give it another couple of days to check if any fresh oil appears.
Any advice or suggestions regarding either problem would be much appreciated. Photos attached to give you an idea of the hole and the leak.
Cheers
Cheers
- Max Headroom
- Banned
- Thank you received: 217
07 Apr 2018 21:21 - 07 Apr 2018 21:23 #191429
by Max Headroom
Replied by Max Headroom on topic Engine oil leak and hole in flywheel bell housing
I can't help you on the hole in the bell housing, but could the oil seen running from the oil filter be simply some residual that was not cleaned off when the oil filter was replaced?
May I suggest you clean off any visible oil VERY thoroughly and get the area as dry as possible.
Check the oil filter is fully hand-tightened and run the car again.
If more oil appears then it could mean that the rubber seal on the filter was damaged on fitment or that the face that the seal mates against has been damaged (that can happen when people stick screwdrivers through an oil filter to remove it instead of using a suitable tool meant for the job).
Sometimes dirt can get between the seal and mating faces if it wasn't carefully cleaned with the filter removed - that could cause a leak too.
Check for any other areas where an oil leak might be coming from that is making it look as if its the filter - e.g. higher up
I'm sure others will come up with some ideas
Good luck!
Good luck!
Last edit: 07 Apr 2018 21:23 by Max Headroom.
The following user(s) said Thank You: apayne
07 Apr 2018 21:22 #191430
by kirkynut
Replied by kirkynut on topic Engine oil leak and hole in flywheel bell housing
Can you give us a photo of the hole. It could be where the clutch adjustment is and meant to be there. If so, there's a plastic cover for it which can fall out.
In respect of the oil, it sounds like whoever changed it couldn't be bothered to clean up after draining it or it is leaking from the filter. If oil re-appears, perhaps get a new filter. They're only about a fiver and pop it on, putting a little oil on the rubber seal so as to stop it tearing as you tighten it hand tight.
Maybe try nipping the current one up by hand a little tighter in the meantime.
- Max Headroom
- Banned
07 Apr 2018 21:26 - 07 Apr 2018 21:46 #191431
by Max Headroom
Yes, as Kirkynut says - if you replace the filter make sure you wet the rubber seal with clean oil before fitting it. Then tighten fully but only by hand
EDIT: Also make sure that there is no dirt on the face that the oil seal mates up against
Last edit: 07 Apr 2018 21:46 by Max Headroom.
- apayne
07 Apr 2018 21:33 - 07 Apr 2018 21:41 #191434
by apayne
Replied by apayne on topic Engine oil leak and hole in flywheel bell housing
Last edit: 07 Apr 2018 21:41 by apayne.
- Thank you received: 1975
08 Apr 2018 05:20 #191440
Replied by Lambert on topic Engine oil leak and hole in flywheel bell housing
Welcome to the forum. If you have only just bought this from a garage it's not up to you to set to and fix it. The supplier is obliged to rectify issues for the first 6 months under statute. It's a Suzuki after all, not a land rover, they're not supposed to leak anything.
Time to create page: 0.168 seconds
