POWER!
- DanRigg94
03 Apr 2018 16:05 #191236
by DanRigg94
Replied by DanRigg94 on topic POWER!
had standard little road tyres on with no tread when i got it. got offered the tyres off a friend who had no use for them anymore. so they are just a temporary fix until i sort some decent ones out. What tyres would be best reccomended for the 15s?
03 Apr 2018 16:20 #191238
Replied by Daniel30 on topic POWER!
Have a read they are very large without changing the gearing
www.bigjimny.com/mediawiki/index.php?tit...age_-_best_practices
03 Apr 2018 16:55 #191239
by sniper
The rolling circumference of a standard Jimny tyre 205/70 x 15 is 2040mm, your running 265/70 x 15 at 2297mm per rotation.
Every time the wheel turns, you travel 257mm further than a standard car, a difference of over 10%.
So your gearing needs to be reduced by 10% to get back to normal performance, but.... that won't be a "normal" load on the engine and performance will still suffer.
You need to make a compromise to best suit your needs, big tyres look cool but cost in many ways, loss of performance due to gearing, a huge increase in unsprung mass ( the weight of the axle and tyres) and a massive change in friction.
If you've got a road car that you play with at weekends, keep two sets of tyres and change them when you play.
I run 215/70 x 15 which is only 57mm bigger than standard, it still gives a noticeable difference in gearing and I use third gear much more than I did.
sniper
sniper
03 Apr 2018 18:46 #191243
Can you tell us the size please because I wouldn't necessarily blame them - Jimny can be a little underpowered compared to mainstream motors.
Replied by helijohn on topic POWER!
DanRigg94 wrote: still standard as far as i know, not too sure if the tyres are remoulded but i bought them a couple of weeks ago for £60 so couldnt refuse them. Any reccomendations on a different box or what i could do to mine?
- mdog18
03 Apr 2018 18:49 #191244
by mdog18
Replied by mdog18 on topic POWER!
I'm in full agreement with sniper. 265 tires will definitely have a negative effect on engine performance! I'm running BFG KO2 AT 215/75/15's on my Jimny which, in my opinion, don't compromise too much on engine performance while still giving the car more girth and beefiness for that rugged off road look!
03 Apr 2018 18:50 #191245
by sniper
Just had a look at the link Daniel provided and some of my numbers disagree, they are taken from errolstyres.co.nz, a source I've used for years and I am confident in their info. having modelled gearing on it in the past, successfully.
Please confirm numbers yourself.
sniper
sniper
Time to create page: 0.196 seconds
