Diff Drain Plug Removal
  • Daniel30
20 Jan 2018 19:32 #188627 by Daniel30
Replied by Daniel30 on topic Diff Drain Plug Removal
That looks fantastic would love to drive in that
Great pictures
20 Jan 2018 20:13 #188631 by furo
Replied by furo on topic Diff Drain Plug Removal
Thanks mate, it was so much fun! It's Glen Orchy, near Glencoe.
  • Daniel30
20 Jan 2018 20:50 - 20 Jan 2018 20:51 #188634 by Daniel30
The more I look at the pictures the more jealous I get
:D :D
In fact can you delete them now pls............
Last edit: 20 Jan 2018 20:51 by Daniel30.
20 Jan 2018 21:27 #188642 by furo
Haha! Sorry about that. Back in slushy Glasgow now :(
  • mickt
21 Jan 2018 12:47 #188671 by mickt
Replied by mickt on topic Diff Drain Plug Removal
As regards the drain plug I am assuming you used a 10mm square bit and not a 3/8 AF as they are so close in size it is difficult to tell which is which. If it was the 10mm did you give the bit a good hit with a hammer when fitted to the plug as that can help loosen any corrosion that is holding it in. It is vital too to keep the plug bit square to the centre of the plug when turning the t bar(as opposed to a ratchet) and that can be done using a jack pressed against the t bar just enough to hold it square and still be able to apply maximum torque. If that all fails you could drill the centre of the plug as you have a replacement to a size big enough to get a hacksaw blade in to cut the thread enough to weaken it to allow the chisel to finish it off.
Time to create page: 1.870 seconds
